Sponsored by: Real Truck
A/C Guage settings????
Old Dec 21, 2005 | 02:16 PM
79CEEJAY's Avatar
79CEEJAY
On my '02 Crew, I have noticed that the A/C seemed a little weak. I added about 1.5 lbs R-134. It seems to cool ok, but when I put some real guages on it the low side reads around 25-27 psi and the high side sits around 150. It is giving me around 41-43 degrees at the vent. I have not checked for leaks yet, but I want to know what readings I can expect from the guages.
The reason I want to learn this myself is that all the auto A/C shops are theives around here and I want to learn about it also, sooooo are their any air conditioning experts out there?
Old Dec 21, 2005 | 02:23 PM
l-m tech's Avatar
l-m tech
depending on outside air temp and air flow through the condenser your low side will read 30 - 40 psi and the high side is usually 150 - 275 . from what im told from the old guys in our dealership the low side usually reflects discharge temp out of the ac ducts.
