Glow Plugs
Old Dec 30, 2005 | 08:44 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
They kick in - I've found at even 90 degrees for a few seconds.
Old Dec 30, 2005 | 09:07 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The glow plugs are only for starting.
Since the only source of ignition is the heat created by compressing the air, when the engine is at outside air temp degrees it is hard to raise the air temp to 494 F by compressing it one time.
Since the air is blown out the exhaust after one compression stroke and more cold air is drawn in the engine only gets one compression shot at making enough heat to ignite the diesel fuel
Old Dec 31, 2005 | 08:21 AM
Saigon's Avatar
Saigon
Thumbs up GP's
Personnally I have been using bosch plugs for a few years now, with a manual switch, and have no problems even in cold weather.
Saigon
Old Dec 31, 2005 | 09:00 AM
flamenco5555's Avatar
flamenco5555
how do u wire up a manual switch? do u completely bypass the glow plug controller and run toggle through relay(s)? how many aps is your relay if u wire it that way. thank!
Old Dec 31, 2005 | 09:14 AM
Saigon's Avatar
Saigon
Thumbs up Bosch GP's
I would say better,went through all kinds of brands for the last five years and Bosch are the ones that have given me the most satisfaction!
Saigon
Old Dec 31, 2005 | 10:28 AM
SomeGuyFromTEXAS's Avatar
SomeGuyFromTEXAS
Flamenco5555,
Try this link from Ziggie's page. Also how do those glow plugs work that you bought?
http://www.members.shaw.ca/k2pilot/G...%20diagram.jpg
Old Dec 31, 2005 | 10:34 AM
Dave Sponaugle
flamenco5555, what year is your truck?
If you go to "User CP" to the left of the blue bar above and then click "edit signature" you can enter your truck info in the signature field. It makes it easier and faster to answer your questions.
If you hold your mouse pointer over the "Signature" to the right of the grey header in my post you can see what I mean.
Old Jan 1, 2006 | 04:06 PM
chrisjrosenbohm's Avatar
chrisjrosenbohm
on my 93 7.3 na i had a push button if it was 70 degrees or moree i didnt need to cycle the plugs it would fire right up below 70 it took some cranking below 60 it would not start with out cycling the plugs
Old Jan 1, 2006 | 05:55 PM
trike1946's Avatar
trike1946
flamenco, I believe your controller is the same as my 90. There is a white wire on one of the terminals on the gp relay. Take it off and tape it up. Run another wire from that terminal to a push button switch and then to good ground. You are completing the ground to make the relay work. I hold mine for about 8-10 seconds when it is cold. I usually don't have to use the gps after the first time in the morning. In the summer I usually don't have to use them at all.
mrsvegan
17
Oct 19, 2013 07:26 PM
KRDiesel
Nov 23, 2012 08:56 PM
fancyvern
Sep 26, 2012 12:37 AM
Attilak1
Mar 5, 2008 07:50 AM
powerglyde1234
Nov 7, 2005 10:31 PM
