Sloppy shifting NP435
Old Nov 26, 2001 | 02:15 PM
jlasater's Avatar
jlasater
Old Dec 16, 2001 | 03:18 PM
jeepcj8's Avatar
jeepcj8
A couple of days ago my shifter became sloppy, neutral was difficult to find. I went to the gas station, and in my search for neutral, I went for 3rd, and the shift lever went way up, and now it is stuck in a high 3rd shift position with the gears in 4th. I pulled the shift tower off, but could not find anything wrong. Do I need to re-build the transmission? It always shifted well and didn't make noise, well, except in 3rd, the most used gear when pulling hills. It has 190k miles on the transmission.
Thanks for advice,
Lisa
Old Dec 16, 2001 | 04:15 PM
1ole4d's Avatar
1ole4d
You might want to check the pilot bearing. Mine is doing the same, making noises in 3rd and now it grinds when the clutch is in and in gear. I was told to check the pilot bearing. I don't have the time to do it right now but when (and if) I get to it I'll keep you posted.
Please don't pull out in front of me! I can't afford to play "What's this?" with you or your car.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
