Sponsored by: Real Truck
Vent air is warm???
Old Dec 20, 2005 | 11:31 PM
mj6gte's Avatar
mj6gte
Question Vent air is warm???
2005 F250 6.0 When I just use the vent, the air is quite a bit warmer than the outside air. I *assume* (bad bad word) that this is not normal and a trip to the dealer is in order?
Mike
Old Dec 20, 2005 | 11:39 PM
rray32539's Avatar
rray32539
Why would you assume that? The vent air is going through the A/C and heater box, it probably does pick up some residual heat from the heater core (not much, though) If you have the automatic climate control, and you have the system on AUTO, having the system blowing through the defroster vents for a few minutes in the morning bothered me until I found out that it was normal. If it does bother you, though, I don't think the dealer or an independent shop would mind giving it a quick look over.
Old Dec 21, 2005 | 07:13 AM
rblomquist's Avatar
rblomquist
My vent air is very warm at first and if I'm stop-and-go driving it's warm. It is fine when the truck is traveling at a decent speed though. The hotter the ambient temps are the warmer air comes through on the vent setting. I just figure the vent air is drawn in around hot areas under the hood and it takes fast airflow to overcome the warming effect.
Old Dec 21, 2005 | 08:16 AM
sandblaster's Avatar
sandblaster
My 03 did and my 04 has the same issue, vent air warmer than the ambient outside air. Never had it checked out so I don't know if its normal or not.
Old Dec 21, 2005 | 10:05 AM
mj6gte's Avatar
mj6gte
That states it well....I was thinking the same thing until recently, when it seemed to be sometimes comming out warmer. You are right, I'll just forget it, the truck is great! The service tech would love me, though..."recently, seemed, sometimes".....I thought of retyping this...taheckwiddit.
Old Dec 21, 2005 | 04:31 PM
rblomquist's Avatar
rblomquist
Yeah it's one of those things that if you brought the truck in they might mess something up that wasn't broke to begin with
Old Dec 21, 2005 | 07:11 PM
6overZilla's Avatar
6overZilla
I have the same situation with my '04 F250 6.8L. Vent air is almost always a tad warmer than the outside air. Judging by the replys so far, this is normal for these trucks.
greentruck72
Mar 9, 2015 03:23 PM
waraas
19
Jan 4, 2012 03:43 PM
pdiesel
6.4L Power Stroke Diesel
Jun 8, 2011 07:07 PM
navistar82
15
Jun 11, 2009 12:39 AM
v10kenj
Dec 15, 2003 03:21 PM
