Offroad & 4x4
Pinion and ring gear???
Old Dec 20, 2005 | 06:08 PM
s_floater's Avatar
s_floater
Will the ring and pinion in my 79 D44 Fit into a 86 D44 front end. Dont want to buy new gears unless i have too. Thanks scott
Old Dec 21, 2005 | 12:16 AM
monsterbaby's Avatar
monsterbaby
yes it will
Old Dec 21, 2005 | 11:49 AM
andym's Avatar
andym
There's a carrier break at 3.93 for the Dana 44. If you're changing ratios, and one set is below 3.93 and the other above, I believe you will have to change carriers as well.
Old Dec 21, 2005 | 03:58 PM
s_floater's Avatar
s_floater
OK the ones in the 86 are original 350's what ever is common for stock. The ones in the 79 are 411's i want to put them in the 86. Thanks for the info Scott
Old Dec 21, 2005 | 04:15 PM
monsterbaby
if you have the entire carrier for the 79 it will work in the 86 TTB unit, you will have to setup the gears with new bearings but they use the same ring and pinion, and the same carriers between those years but andym is correct in that there is a carrier break and the 4.11 gears will use a series 4 carrier which they should already be on in the 79 axle.
Old Dec 21, 2005 | 04:18 PM
s_floater's Avatar
s_floater
thanks alot thats what i wanted too hear. Starting a new mudd truck and trying to save money so this will help.Thanks scott
Old Dec 21, 2005 | 06:22 PM
The SnoMan's Avatar
The SnoMan
Need to consider carrier break as others have mentioned and whether it is a reverse rotation or not (you can tell by a high pinion on rev rotation axle as the gears will not interchange between a rev rotation and a standard one) Ford used a rev rotaion in front in some older model 4x4's
Old Dec 21, 2005 | 06:34 PM
1970Custom's Avatar
1970Custom
If I'm not mistaken the late 70's solid D44 and the TTB D44 were the same internials so there shouldn't be a problem.
and from his post hes got the complete '79 D44 so hes in the clear.
Old Dec 21, 2005 | 06:52 PM
The SnoMan's Avatar
The SnoMan
It is very easy to ID a rev rotaion unit. The difference is easy to see. I know Ford used them some, just not sure of the years and applications.
Old Dec 22, 2005 | 12:32 AM
monsterbaby
try from sometime in that late 60s through the end of them using D44 front ends including the entire time they used them in the TTB front ends.
Actually Dana first released the HP D44 in Jan 1965, and they can be found under a few rare 65 F100s, and were used from then on.
Old Dec 22, 2005 | 03:08 PM
andym's Avatar
andym
Also, just to be picky, it's a reverse spiral, not a reverse rotation.
Old Dec 22, 2005 | 06:58 PM
1970Custom's Avatar
1970Custom
I don't mean to sound stupid, but isn't that the same thing??
Every listing I've seen on the D44 said 4.10 or 4.10 rev. rotation.
Old Dec 22, 2005 | 07:22 PM
monsterbaby
No actually it's not the same thing, the axle still rotates the same direction as any other axle but the proper way of stating it is reverse cut gears, this is done so that since the pinion is put above the center line of the axle, and the ring gear is put on teh other side of the pinion if you didnt' cut the gear in a rev pattern you would be running on the coast side which wouldn't be as strong.
Old Dec 22, 2005 | 07:31 PM
1970Custom's Avatar
1970Custom
Something I didn't know, thanks Rob.
Do you know anything about building engines?
Sorry had to ask it.
Creamsicle88
Mar 1, 2016 10:10 PM
firstrider
Jan 23, 2016 06:57 PM
obx 79 shortbed
Aug 30, 2014 10:20 AM
tastyklair
Feb 2, 2005 08:33 PM
Rob Cuenin
Jan 7, 2005 05:11 AM
