signal flasher...
Old Dec 20, 2005 | 02:31 PM
ltfox's Avatar
ltfox
signal flasher...
On my 2000 explorer, the right signal flashes real quick 90% of the time and normal the other 10%. The left signal is normal. Whats up?? is their a flasher relay that could be bad?
Old Dec 20, 2005 | 07:46 PM
JerrySimm's Avatar
JerrySimm
Probably not the flasher since it works both the left and right. More likely the multifunction switch. I've noticed on my '03 that if I don't move the turn signal lever quite far enough when going to the right it will flash real quick, but I can't make it do it to the left. Are you sure you're moving the lever far enough? If so, whatever it is that makes it do it on mine when it's not far enough, may be making yours do it all the time.
Old Dec 21, 2005 | 06:59 PM
ltfox's Avatar
ltfox
Thanks.... I play with it and check it out.
Jason6969
Sep 14, 2022 03:00 PM
PRUSue
Sep 25, 2013 11:38 PM
onriver365
Jan 6, 2013 08:49 PM
karichjr
Sep 26, 2011 06:40 AM
lexustbs
6.7L Power Stroke Diesel
Jan 26, 2011 11:07 AM
