i have a 78 f-150 and i am looking to put fuel injection into it, i would like to know if the is all right to do and how hard it would be, or i would like to know if you can take fuel injection off when the spark plugs are in the manifold, please reply ASAP
OK here's your reply...
Seriously, you're going to have to provide a lot more information and phrase your questions a little more clearly to get a legitimate answer.
holley makes a throttle body injection kit, theyre ok, i had one for a while but couldnt get over some of adjustment the problems. just real expensive and kinda a pain to set up. but ive heard good things about the new ones.... if you can handle the price
-Sam
Bradley, Tell us more about your truck.. Engine, transmission and more. Then, do you drive this truck daily or do you race it? What are your skill levels when it comes to working on your truck? Do you have tools, a shop, friends that are mechanics? I always advise beginners on small budgets to go slow. If your budget is unlimited bring the truck over to my house and I'll do all the work for you! You should fix and or replace all the things needed to return your truck to a safe dependable driver. Then improve it from there. We can help big time. Also check out the engine boards on this site.
William in Atlanta
I tried to use the Barry Grant V.F.I. unit that replaces the carb. All I got for my trouble was a ruined motor from fuel drowning. Most of the aftermarket system are going to have issues with computer interference from a "hot" ignition system.
