wiring tachometer
Old Dec 19, 2005 | 02:54 PM
turdbird's Avatar
turdbird
wiring tachometer
my 96 f150 eddie bauer 300 5spd doesnt have a tach, how does one go about installing an aftermarket tach? i dont know anything about wiring so please no techno-jive talk.
Old Dec 19, 2005 | 04:34 PM
subford's Avatar
subford
One wire for the tach goes to the Spark Generating Device, the Tan wire with a yellow stripe down it. The other wire goes to a screw that screws into the metal body of truck. If it has a wire for lighting it up at night, hook this wire to wire that lights up the ash tray, a Light Blue wire with a red strip down it.
Old Dec 19, 2005 | 07:09 PM
Franklin2's Avatar
Franklin2
The tach will come with instructions. It has a power and a ground connection like anything else you hook up in a vehicle. You can hook it up to the fuse box or use the radio power wire that goes on and off with the keyswitch.
The signal wire will hook to the - of the coil.
Like subford said also, it will have a wire for the dial illumination. Tap into one of the dash lights for this.
