Since the winter here in NE appears like it will be a doozy, I am considering a plow for the front of my 92. I have looked at all of the plow manufacturers, but frankly don't want to spend the $4,000+ to have one mounted to the truck.. I am considering at this point getting a SnowSport plow which simply drops into the front receiver.
Here is my dilema.. I can't locate a front 2" reciever for a Bronco.. Any suggestions?
Happy Holidays everyone..
Thats because no one makes one. The strange "accordian" reinforcement to the frame horns at the front of the Bronco and F-series makes mounting a reciever more than a little bit tricky. People have done it but it takes some custom fabrication up there behind the bumper to safely mount a receiver.
So anyone that has fabricated one out there.. If you have any information on this proceedure, please let me know.. I would like to see some specs or something before I stop by my local welder, who is probably overly busy this time of year anyway..
I would seriously reconsider putting a plow on the front of a Bronco. If you're going to do it, which also means beefing up the front suspension, and you're talking about plowing 'doozy' amounts of snow, you're going to kill the Bronco in short order. They are not made for plowing at all. They are definitely not made for plowing large amounts of snow.
There is also a right and a wrong way to do things. Mounting a plow on a front receiver hitch falls under the 'wrong' category.
Andym has a good point in that the Bronco is a relatively short wheelbased vehicle for plowing. Not that I haven't seen it done. Its just that the Bronco is pretty front-heavy to begin with given that its basically a 1/2-ton F-series with a tiny little bed behind it. Most of the Bronco's I've seen adapted for plowing have added a large salt hopper to the rear to help with the weight distribution. The leverage needed to plow is harder to acheive with such a short wheelbase. Kinda like standing right behind the shovel when you clear the snow by hand as opposed to standing back a bit where you can get better leverage at the maneuver. If you try to shovel starting right at your feet its really hard to get the shovel started. But if you are back from it a couple of feet you can get the leverage and power to push the blade of the shovel under the snow. Its a similar situation with the Bronco and plowing, just on a larger scale. Obviously the choice is yours. I have seen enough Broncos equipped to plow but they are usually operated by the owner of the small lot(s) they are expected to plow and don't see much heavy plowing at all. Just the occassional clearing of a service station or small used car lot.
I have atually had plow trucks in the past.. Mostly F-350's, some 250s. I'm at a stage now where I have no desire to go out and plow driveways for$$$$.. Just looking to clear mine..
The plow I am talking about is http://www.mysnowsport.com/. Which is a VERY light weight setup... Intending it only to be used for an inch or so of snow..
I must admit, I did consider going for a full blade plow.. The idea was quickly dispatched due to cost, and modifications to the truck.. I was hoping this one would simply save my back.. I may wind up having to sell the old girl and go back to a pickup, for that reason alone.. I was hoping to get throug it though....
If you are thinking of switching back to a pickup just to plow your driveway don't despair at the shop I used to work at they used a Bronco to plow their lot. The only modification they used was to put air bags inside of the coils in the front. Just fill them up with air when the blade is on. Or there are companys out there that make custom front bumpers that have reciever hitches on them for winches. I would think that if the bumpers were strong enough to mount a winch to you could put one of these small plows on them.
I've seen enough Jeeps out there with plows on them to think that Broncos can't be that bad for homeowners only wishing to plow there own driveways.
There was a guy in Ontario I knew that had a plow on his 78 and he plowed all over the area for $$$ and never had any problems (so he claimed). I watched him push snow that was coming back over the top of the blade across the yard for 40-50 ft with minimal wheel slip. I guess it all depends on what you want. If you are only doing your driveway and looking for a low cost method - why not!
I Have seen many plows on Broncos.. I know the Jeeps are built with Front Leaf springs, that alone makes a big difference.. After seeing the one listed below I may just look into it..
Thank SO Much for your suggestions.. I'll let everyone know what I come up with, and will post pics..
www.draw-tite.com has it. Lists for 92' F150 part # 65011 $145.48 plus shipping. I have another model of this on 99' F150. Front end hitches are listed on left of main page.......
Why not look for a used plow set up? If you are only going to do your own driveway. I put one on my 87 and have uaed two winters now with no problems. I bought it off a guy that had it on a 87 150. I called and asked him if he would sell just the plow and he did. I like using the bronco to plow becouse of the turning radius. I only do my driveway and the end of my road. I live on a dirt road and the end of the road is on a bad corner so town truck doesn't spend to much time on it. It is a western plow 7ft and it is not that heavy. It doesn't drop the front end much when I lift the plow. It only drops about a 1/2" and I don't have air bages on it either. I would have to do a lot more shovling if I had put it on my pickup.
I have a 88 Bronco that I use for the sole purpose of plowing. I have a Meyer 7.5' blade on it and yes it does drop the front end right now when I lift the blade, but as far as what the other guys are saying, I have NO problem using it to plow with. As a matter of fact, a few of the guys that are using trucks said they wished they had the Bronco for some of the stuff that they do. I've got the 302 with the rv cam in it and right now an automatic with the electronic 4X4. I'm going to be switching the 2 88's that I have to make a nice one. Mine now has lived north of the rust belt for 17 years so you know what the body looks like. Watch out for the "el cheapo" blade and setups, because you definately get what you pay for in plows. They have fiberglass blades now that don't weigh as much as the steel ones.
I have plowed with both Broncos and K-5's for many many years. As far as the short wheelbase.....well thats exactly what I like about it.....no salter or too heavy up front bla bla.....nothing! The short wheelbase makes it perfect for getting in and out of tight places, and making u turns. The enclosed bed is perfect for tools spare tire (I keep it in there for better visibility out the back).
The thing that I cant live without while plowing is a seat that will recline and slide.......I MUST be comfortable while plowing, in a pick up I cant lean the seat back and it kills my back after a few hours. A pick up with a crew or extended cab will work fine.
So.......all in all, I will take a full size Bronco w/351 (even with a 302) for plowing any day, and with just a bit of common sense and things like a trans temp gauge, leveler springs and quad shocks up front......a tranny cooler......ect ect.......it will be just fine........as with anything like this you cant cowboy the **** and expect it to last.
