New Here..with some questions
Old Dec 19, 2005 | 01:23 PM
2004Redline's Avatar
2004Redline
First off thanks for any answers you guys can give me. Ok I just bought and 87 F-150 I6 4x4 4speed. I did the normal tune up stuff(plugs, cap, rotor, air filter, pcv, breather sys, & serp. belt.). After doing this I started her up and she was idleing at 3000k. So i figured maybe when I sprayed the throttle body with cleaner that I screwed up the IAC. Well after replacing the IAC it is still idleing at 3k. I think it maybe a vac leak but I have no idea where to start looking. Also if possible could someone send me pics of what the engine bay should look like cause there is a few things that I have no idea what they are for.
Thx,
Matt
Old Dec 19, 2005 | 05:53 PM
5_labsownus's Avatar
5_labsownus
First the basics by looking at the vacuum lines to see if any are off there port or broken. Then get a 2-foot length of ½-3/4 inch hose and place one end to your ear and hold the other to the engine bay and move it around. You will hear a high pitch whistle from a leak.
Old Dec 19, 2005 | 06:34 PM
quicklook2's Avatar
quicklook2
go and buy a manual if you do not have one. it will help you more than anything else you do.
disconnect the battery to reset the computer.
i had a brand new iac from napa that was bad. so that may be a possibility.
how did it run, idle before? you did a lot of changes at once, the chances that you knocked something off is very possible. get a good light and really look around where you had done work.
and, welcome to fte.
Old Dec 19, 2005 | 08:18 PM
2004Redline
Before i started anything it idled around 1500. Im pretty sure that the leak has to be on the drivers side of the engine because it didnt do it until I changed the oil filter. I did notice that there is a green line(pretty sure vac) that is broke. It goes from what I believe is the egr to a kind of tee above the #6 spark plug. BUt it is only 1/8" line I find it hard to beleive that one little line could be the culprit.
Thx,
Matt
Old Dec 19, 2005 | 08:23 PM
quicklook2's Avatar
quicklook2
than you will be amazed at how small things can stop such a big truck.
reconnect that line and see if it helps.
and 1500 was too high an idle to begin with.
Old Dec 20, 2005 | 10:40 AM
2004Redline
yeah replaced that line....no fix...I was think maybe the tps, the only problem is I cant get the old one off. I already have a new one. I just got home from work and disconeccted the battery to maybe reset the ecm. On the pass side of the engine comp. there is a black box mounted the left and below the battery...what is that? One of the vac lines goes to the tee that splits to each side of the throttle body.
Thx Again,
Matt
Old Dec 20, 2005 | 11:55 AM
quicklook2's Avatar
quicklook2
this post goes on for two pages and may help you out:
https://www.ford-trucks.com/forums/s...8&page=1&pp=15
