I wasn't so much looking for a step-by-step but was wondering:
1) How did you seal between the bumper and the light/mount;
2) Is the light mounted via the normal mounting lugs or is it mounted via it's circumfrence;
3) Is the mount welded to the bumper and if so, I'd assume the bumper is painted;
4) If the mount is not welded to the bumper, what did you use to cover the edge of the cut-out.
A pic from the back of the bumper, inside the wheel well perhaps, would be worth a thousand words.
If you can, thanks, if you can't, thanks anyway.
Later... Brewster...
1. Weld
2. Both
3. Yep, welded and painted.
4. Better pic from my 07:
Originally Posted by big poppa pump
Appreciate the response DC, after the holidays i'll get back to yaa. I seen some knock offs at the Carlisle truck show this past year, i know what you mean..are they metal or fiberglass ???
All Fiberglass
Originally Posted by 08f250
...Who did that custom superman logo cause i was looking for a custom Billet or black billet logo
DC....have you noticed a rise in engine temp with those lights mounted in front of the coolers/radiator? i have a set of hella 550's i want to mount like your setup. thanks Britt
Hey DCSpecial, I was wondering how you ended up wiring your lights. Did you follow the instructions and tie into the high-beams or go an alternate route? Your help is much appreciated.
I like the way DC mounted the lights in the front bumper....Im thinking about doing that only thing is that I think I need special brackets to weld in.
~Gage~
