87 302ho Efi
Old Dec 19, 2005 | 11:00 AM
clemet's Avatar
clemet
87 302ho Efi
I just purchased a 87 Bronco with a 302HO and as I always do I want to start designing a new motor for this truck. As this is the first EFI motor I am going to do I was curious is how much the EFI in these trucks flow in the equivelent of a carb. Also would it be cheaper to just carb it and be done?
Old Dec 19, 2005 | 05:08 PM
johnsonswamp's Avatar
johnsonswamp
I'm not sure just how much the EFI can handle. If you are going to modify it a good bit I would carb it. I'm not a big fan of any factory EFI system. This is just my personal opinion.
Old Dec 20, 2005 | 12:30 PM
Kemicalburns's Avatar
Kemicalburns
your efi is speed density. it can handle various upgrades like heads, headers, cam, intake,throttle body. the key is the cam, find one with a lob seperation no less then 114* and everything else will be happy. oh dont change the injectors either. the stock 19lb ones will work just fine. a 5.8 swap can also be done, its a drop in swap and bolts right to the tranny. a few minor things will need changed but this would be the optimal gain especially with a few mods as well.
check out www.fordfuelinjection.com
