4 wheel drive/transfer case
Old Dec 19, 2005 | 10:40 AM
johnnym's Avatar
johnnym
Angry 4 wheel drive/transfer case
I recently purchased a 1995 5.8l f150 and when i put it into 4x4 high, the dash light comes on but i don't have 4 wheel drive. The hubs make a noise and when i come to a complete stop they click, but do not engauge. Also when i am driving in normal range, there is a low whining / humming noise whish gets louder when i let off the gas. CAN ANYONE ADVISE WHAT MIGHT BE WRONG.
Old Dec 21, 2005 | 09:41 PM
tuekwik's Avatar
tuekwik
Do you manual locks or auto locks?
Old Dec 22, 2005 | 12:41 PM
johnnym's Avatar
johnnym
I have auto hubs
Old Dec 22, 2005 | 01:00 PM
aurgathor's Avatar
aurgathor
Most likely, the auto hubs are shot, or overgreased. The latter can sometimes be remedied, but you're usually better off installing manual hubs as they're a lot more reliable.
Lift all 4 tires up in the air, start engine, put into gear and 4WD, and check if the front shafts are spinning. If they do, it's the hubs with 100% certainty.
Old Dec 22, 2005 | 07:25 PM
RTM's Avatar
RTM
I second the manual hub swap. Put the truck in 4x2 and jack one side up and then turn the front drive shaft by hand and you should be able to see the hub slipping and making noise.
Keny1
Dec 25, 2021 05:13 PM
wardnikolaus
Dec 28, 2015 04:17 PM
diggerdog
2009 - 2014 F150
Aug 25, 2015 06:29 PM
jayron
1997 - 2003 F150
Dec 29, 2014 07:48 PM
Pearlwhite94
Jul 26, 2008 03:16 PM
