Transfer Case Noise
Old Dec 23, 2015 | 05:59 PM
wardnikolaus's Avatar
wardnikolaus
Transfer Case Noise
I have a 1995 Ford F250 4x4 with manual locking hubs. The noise started as a low growl above 30 mph with the hubs locked and the case in 2 wheel drive. The noise sounds like it coming from the either the front end or transfer case. When I put it in 4 wheel the noise would go away. I recently put a 4 inch lift and 35s on the truck and the noise went from a low growl to a grinding/chattering noise, like gears trying to mesh. In 2 wheel, with hubs locked, the noise is constant. When the truck is in 4 wheel, the noise happens when there is no pressure on the drivetrain. When accelerating or coasting,in 4 wheel drive, the noise goes away. I just had new U-joints put in the front driveline so they are fine. Any ideas on what it could be?
Old Dec 23, 2015 | 07:23 PM
Mudsport96's Avatar
Mudsport96
Maybe check front diff fluid level?
Old Dec 23, 2015 | 07:35 PM
wardnikolaus
The mechanic who put in the U joints said the fluid was fine.
Old Dec 23, 2015 | 07:46 PM
PRIMERED79 SHORT BED's Avatar
check the fluid in the case?
Old Dec 24, 2015 | 08:34 AM
Mudsport96's Avatar
Mudsport96
Could pull the front driveshaft and lock the hubs in go for a drive. If it makes noise its in the front end. If not leave the driveshaft out unlock front hubs and engage four wheel drive noise equals transfer case problem no noise leaves driveshaft u joints. Process of elimination
Old Dec 28, 2015 | 04:17 PM
wardnikolaus
I don't have the resources to tear it apart myself. I was just wondering if someone had something similar happen. I am thinking of buying a rebuilt transfer case but I want to be fairly certain that is the problem before I go and put more money into it.
nxtdiesel
May 26, 2020 11:13 PM
Ilovemypuppy1
Mar 15, 2018 06:54 PM
Whisker
Sep 26, 2013 04:03 PM
teamlx88
General Automotive Discussion
Mar 6, 2011 02:29 PM
Jake84
Jan 2, 2007 12:36 PM
