Sponsored by: Real Truck
steering noise
Old Dec 19, 2005 | 09:45 AM
1stFordF250's Avatar
1stFordF250
steering noise
I have a 05 250 c/c 4x4 psd, and im hearing this noise when the truck is at slow speeds when i turn the steering wheel. The noise almost sound's like something is binding. I also feel it in the steering wheel itself when i just first move the wheel to the left or right. Anyone have any ideas what this might be, or has anyone had the same problems. Any replies would helpful.
Old Dec 19, 2005 | 10:42 AM
afinepoint's Avatar
afinepoint
Have you checked your fluid level and belt condition?
Old Dec 19, 2005 | 11:05 AM
1stFordF250
Checked fliud level is fine. The belt i didn't check, only reason being the truck only has 5900 miles on it
Old Dec 19, 2005 | 11:16 AM
afinepoint's Avatar
afinepoint
Is there water in the fluid? That can generate noise.
Reg
Old Dec 19, 2005 | 11:27 AM
1stFordF250
Im not sure if there is water or moisture in the fluid. How could you tell if there is?
Old Dec 19, 2005 | 12:21 PM
1stFordF250
The noise sounds like its coming from inside the cab, almost like a low rubbing noise
pspehar
Jul 26, 2015 07:37 PM
lowrider57
Dec 19, 2014 01:42 PM
RAPR
May 13, 2014 01:37 PM
a30ptbuck
Jan 29, 2014 06:29 AM
Gangley
Sep 26, 2013 08:42 AM
