Faceplate for Jensen Headunit
Old 12-19-2005, 09:25 AM
skyrider's Avatar
skyrider
skyrider is offline
I have a 2003 Explorer Sport Trac, I have a double DIN Jensen DVD Head it is slightly larger than the space that is there for the factory unit. Is there a facplate adapter for the sport trac that would accomodate this headunit
Old 12-19-2005, 11:33 AM
CobraXP's Avatar
CobraXP
CobraXP is offline
Welcome to FTE skyrider!
I think you will get more repsonses to your question in the Audio section, so I am going to move your thread there. As for an answer, I cannot help on the plates. I run an Alpine double din in my 97, and had to fabricate a new plate myself after modifying the hole to fit the radio. You may end up needing to do the same...
Old 12-19-2005, 11:48 AM
skyrider's Avatar
skyrider
skyrider is offline
Thank you for your help
Old 12-19-2005, 01:41 PM
fordboy_52's Avatar
fordboy_52
fordboy_52 is offline
www.crutchfield.com
look up your head unit then, find things that go with it.
Matt
Old 12-19-2005, 01:44 PM
fordboy_52's Avatar
fordboy_52
i found this, its for the only jenson they had
http://www.crutchfield.com/S-hIzphiY...K550&s=0&cc=01
Matt
