I'd be concerned if you're making 31psi bone stock. How are you measuring, with a real gauge or the factory gauge on the cluster? 31psi should be considered overboosting for a truck in stock trim.
I have installed a Bully-Dog Monitor on my 04. It can monitor 4 different items at the sametime with a choice of many. Only the 2 EGT's have any installation work other than plug in. I choose the 2 EGT's, boost , & volts which was taken away for the factory trans temp guage. Most of the time the boost is under 10, & under 25 pulling #7000 conservatively...I've seen 30 on the guage once...Good luck
