Sponsored by: Auxito
2003 F150 Starting Problem
Old Dec 18, 2005 | 02:22 PM
GJ10SPEED's Avatar
GJ10SPEED
Hi
First time user looking for help! Wnet out to start 2003 F150, 5.4L 2WD, 72k, and put key in and turned and just a quick click then nothing. Then clicking and other like noises started with key off, put on brake and they stop. take foot off brake and they start again. Shifted gear to R and rolled and stopped and tried again, nothing but the clicking noise. Nothing worked. Then for a short time, the door locks would work, then nothing, more clicking until brake is applied.
Any ideas before I call the Ford shop to haul it in?
Thanks for ideas...GJ
Old Dec 18, 2005 | 04:14 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 18, 2005 | 04:58 PM
PaulC's Avatar
PaulC
Turn the headlights on, then try to start the engine. I'll bet that they dim almost to darkness. If so, battery time.
Old Dec 18, 2005 | 05:05 PM
GJ10SPEED's Avatar
GJ10SPEED
Thanks Paul...I thought maybe the battery was the issue and went out to check the posts, had some corrision on the positive end and cleaned it off, tried and everything flickers, on and off, still no turnover.
When my wife gets home, I'm going to try to jump it with her car and see if it starts and if so, then I am sure it is the battery. If not, I'll call the local garage guy and have them tow it in and hook it up and see what they can figure out.
Thanks for the quick reply...
GJ
ZekeF3
1997 - 2003 F150
Aug 24, 2012 07:35 PM
weaver79
1997 - 2003 F150
Nov 18, 2010 12:08 PM
nolanb
Aug 18, 2010 07:52 PM
danblackwood
Jun 10, 2010 09:40 PM
stigedis
1997 - 2003 F150
Mar 4, 2010 11:39 PM
