Question on Timing?
Old Dec 18, 2005 | 09:07 AM
Red Raider 4x4's Avatar
Red Raider 4x4
Question on Timing?
Installed a new MSD Distributor, I set the timing a 12BTDC, not 10BTDC, read a post on hear for performance reasons that you could get a little extra out of our Trucks and this was a free modification. Truck seems to be running great, no starting problems, or acceleration problems. My question is I have a custom Diable Chip installed, does this chip not already advance my timing a bit? and should I just put the timing back to the stock setting of 10BTDC? I thought maybe the acceleration might even be better at the stock setting.
Old Dec 18, 2005 | 12:20 PM
EPNCSU2006's Avatar
EPNCSU2006
Ideally, the timing should be advanced as far as it can without causing pinging. As long as it isn't pinging under loads, I'd leave it be.
Old Dec 20, 2005 | 12:04 AM
Red Raider 4x4
No pinging, when I was setting it up, at 13 BTDC and a little before it I had pinging, at 12 nothing, seems to accelerate great. Thanx for the input.
