1978 - 1996 Big Bronco
lifting hte front alingment
Old Dec 18, 2005 | 03:38 AM
GPSMatt's Avatar
GPSMatt
does any one kno how much inch lift springs i can do with just adjusting my camber before it gets way off?
Old Dec 18, 2005 | 04:47 AM
greystreak92's Avatar
greystreak92
1.5-2" is about the limit before you have to deal with axle drop brackets and sometimes even different adjustment shims for the balljoints. In other words you can put leveling springs or a leveling kit under the front and usually still get everything to come into alignment but beyond that it gets tricky. The OEM alignment adjustment doesn't really give you much to play with and the setup rolls the adjustment out of caster and into camber or vice versa depending upon which direction you need to adjust things.
Old Dec 18, 2005 | 11:16 AM
GPSMatt's Avatar
GPSMatt
ah. what about diff alingment cams for the front? ive done front ends on rangers before but this is my first bronco. I work at a fabrication shop and am extending an cuting an turnig a pair of beems but i am just looking for a temp solution untill i finish those
Old Dec 19, 2005 | 02:54 AM
greystreak92
Superlift makes a couple different sets of bushings. You may check with them or a supplier to see if any will get you more adjustment but I doubt it. It doesn't take much change in spring length to throw the camber all out of whack on the full-size trucks.
