360 with a 4 barrell
If you are hauling much of a load regulary, you might need a different engine setup. I am thinking you are working on the outer limits for that engine vr. the load weight. A FT motor would be better than the FE. A 428 crank and piston set to make that a 410 would be a good return.
Oh well, I suspect you'll get plenty of advice on this one.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
John
jowilker email me
I am very slowly putting a mild 390 with a small Autolite 4-barrel together. Maybe by summer I'll have it done and swapped in.
A new Edelbrock Performer manifold goes for $220 at Summit. All the used ones on Ebay are selling for $200 and up which doesn't make sense to me... a used stock Ford aluminum intake just sold for $301!
Rebuildable 1.12 (580 cfm) Autolite carbs are around $35-$40, then plan on another $50 for a rebuild kit and any missing parts. So low $300's, anyway.
A good RV type cam, along the order of the Crower "Baja Beast", a set of small tube headers with at least 2 1/2 inch pipe and balance pipe and free flowing muffers wold go a long way.
I have this set in a 69 F350 with 390 and 4.10 gears, I have 3" exhaust, but 2 1/2 is big enough. This is a Chassis Mount Camper, weights in exess of 10,000 lbs. Pull a 3,000 lb boat. Pulls like a freight train. MPG,,, not something you should expect a lot of, if you really need fuel mileage go Diesel
Of course, if your theory is "damn the cost, give me more grunt!" then adding more cubic inches is the answer. After all, "there's no replacement for displacement." You can either stroke your 360 to 390 or 410 cubic inches, or find a replacement motor like a 390 FE, 391 FT, etc. Stroking a motor is not a simple or cheap job. It requires removal of the engine and complete disassembly. You'll end up replacing the crankshaft, connecting rods and pistons, and all the little bearings, seals, and wear parts along the way (basically a complete rebuild, but with a longer-throw crankshaft and shorter, stronger connecting rods). The cheapest you'd be able to do a 390 or 410 conversion is about $750 if you do a lot of the work yourself, and shop around carefully for deals on the parts you need. Figure on $1250 and up to have a shop do it for you, and add another $500 if you're not willing or able to remove and replace the motor yourself.
I don't agree with the recommendation to replace the cam. The stock Ford cam used in the 360 motors is actually pretty good at producing low end torque and gas mileage. It really limits upper rpm performance and peak horsepower, but you don't need that for your application, anyway. Of course, if you're going to do a 390 or 410 conversion, you might as well drop in a fresh aftermarket cam and lifters while the engine is torn apart.
BTW, What do you use the truck for, What kind of weight are you dealing with?
John
jowilker email me
John
jowilker email me
Isn't it interesting, Karlsd says I don't need my RV cam and Jowilker says I don't need my 4BBL and headers.
Truthfully I can't tell you which change made the most differance, as I Install the Cam,intake manifold, Headers and 3" exhaust at the same time.
FWIW I can tell you this, hills I use to pull in 3rd gear, on the floor, struggling to maintain 50mph I now pull in 4th gear at 60mph + and still have trottle left, so something worked.
If you are going to have the engine torn down, thats the time to do the cam, if not try the headers and big exhaust.
[SNIP]
Yup. That's the usual problem, isn't it? We make a bunch of changes at once, so we have no way of knowing once we're done what changes actually made a difference and how much. The only way to know is by trying things one at a time, and in various combinations, and doing some dyno (engine, chassis, or the ole "butt" kind) testing each time. None of us has the time or money for that. Race engine builders and magazines do, I guess.
[SNIP]
Yup again. I agree completely, though I'd also go along with John and say that the best way to really build torque is to stroke the motor. If you're going to tear it down for a rebuild, anyway, might as well drop in a 428 crankshaft while you're at it.
Absolutely, would have went this route myself if I had the $$$$, However Greg's orginal post didn't sound as if he wanted to go to that extent.
John
jowilker email me
