Unexplained shaking
Old Dec 17, 2005 | 01:35 PM
DannoNY's Avatar
DannoNY
Question Unexplained shaking
I was driving the other day and all of sudden it started shaking like the wheel was coming off. I thought for sure I had a flat so I pulled over. It smelled like dead fish, but I didn't see anything wrong. It didn't do it again until yesterday, driving about the same speed 40-45. Again I stopped and it smelled again. This is strange, but I know it's not going to act up for the dealer and they'll give me the run around. I wanted to check with you guys first to see if anyone has had this. Thanks for the input.
Old Dec 17, 2005 | 03:25 PM
afdt2's Avatar
afdt2
I've read on other forums where that problem is related somehow to the emergency brakes sticking...would look into that especially with the fish smell Maybe do a search here.
Old Dec 17, 2005 | 07:14 PM
turkyhntr's Avatar
turkyhntr
Unexplained shaking
I had the same exact problem on my 04 Scab, and it was the emergency brake sticking. Even though it did not light up on the dash, and you thought it was released, it wasn't. Took the vehicle in to the dealer who adjusted the emergency brake, and checked the brakes for damage, there was none. Since that time 8 months ago no problems.
Old Dec 17, 2005 | 08:12 PM
WhëëlMå1's Avatar
WhëëlMå1
This is the e-brake problem for sure. A simple search in this forum will yield many stories of it.
Old Dec 17, 2005 | 10:26 PM
DannoNY's Avatar
DannoNY
Smile
I used the emergency brake for the first time last week, then the problem started. It has to be that. Thanks alot you guys, I knew someone would know about this.
Old Dec 18, 2005 | 07:31 AM
WhëëlMå1's Avatar
WhëëlMå1
Here is how the dealer wrote it up when it happened to me.
"Concern: Has Rear Brakes Hanging up...vibrating
Correction: Found E-brake accuators frozen...removed L+R Rear Wheels, Calipers, Rotors to Gain Access. Removed, free up, and antiseize both accuators and reassembled.
Old Dec 18, 2005 | 08:48 AM
DannoNY's Avatar
DannoNY
Thank you Rich, at least I can point them in the right direction at the dealer now.
Old Dec 18, 2005 | 05:16 PM
NY-Ford-Lifer's Avatar
NY-Ford-Lifer
Oh do I ever know that scarey feeling and smell! My seat is still stained. My dealer was unable to resolve the problem (despite my exact diagnosis) but then again anything over an oil change is taxing their abilities.
Old Dec 18, 2005 | 06:17 PM
fishead's Avatar
fishead
Post Scary shake
I had the same problem and the dealer repaired it. They had to replace the brake shoe hubs and the shoes. One hub had turned the hubs blue. As with you it was very scary and the only way to stop it was to pull over. There is a TSP on the shoe tolerances.
Old Dec 18, 2005 | 07:33 PM
NY-Ford-Lifer
Blue? Any idea where that TSP info can be found? Thanks.
Old Dec 18, 2005 | 09:53 PM
DannoNY's Avatar
DannoNY
I had my 8 year old son with me and we were supposed to just run to the video store when the truck started shaking. I thought we'd be out there changing the tire on the side of the highway. It was annoying and a bit scary, but I'm glad the tire wasn't flat.
Old Dec 21, 2005 | 09:44 AM
centexKR's Avatar
centexKR
not just a Ford problem. Had a 02 4x4 Avalanche. The parking brake always went to the floor since picked it up with 2 miles on it. After about 60000 a local dealer asked if had the e-brake serviced. The advisor looked at and said its not working, I
replied than it never has since been that way since new. No smell, feeling, nothing but the rear rotors were completely torn up, a $700 to me. I felt this was a design flaw and chevy should have stepped up. Advisor said finding lots of them but GM will not fix it.
Old Dec 21, 2005 | 03:16 PM
NY-Ford-Lifer
I have yet to use the e-brake since this past summer. The repeated failure of it has frightened me to the point of learning to live without it.
Old Dec 21, 2005 | 06:46 PM
DannoNY's Avatar
DannoNY
I made an appointment with the dealer and told them what I (we) think is the problem, they say, "I doubt that's it, but bring it down and we'll check it out". I'll probably get it back with the typical response, "we couldn't get it to do anything out of the ordinary".
Old Dec 21, 2005 | 08:04 PM
YOMAN's Avatar
YOMAN
your from long island ? if you do.. i may be help you to figure it out what went wrong...
if your not from long island then hope your dealer will be ncie to you
Keep us posted!
YOMAN!
