code 1211 on cold starts?/
Old Dec 17, 2005 | 01:19 PM
wycowboy's Avatar
wycowboy
I 'm getting this code on cold starts .. thise is Ip out of spec too high or low.. is this from the 10K getting loose the sctm or do I have a real problem?? Soould I be woried about a break down ?? thanks J
Old Dec 17, 2005 | 01:26 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I don't think it's a problem. The pressure will always be higher when the oil is cold, and with the tuner and resistor both calling for increased pressure it's probably just a little out of range high until the oil warms up.
