Sponsored by: Real Truck
Overdrive
Old Dec 17, 2005 | 12:17 PM
bigblu250's Avatar
bigblu250
Overdrive
The other day I noticed my overdrive wouldn't disengage while driving down the road. After some investigation I found out overdrive will disengage in any gear except drive, functions fine in any other gear. Just wont turn on or off while in drive. Any ideas what could be wrong? Thanks for the help.
Old Dec 17, 2005 | 02:19 PM
tvsjr's Avatar
tvsjr
Are you referring to Overdrive (which is just another gear) or torque converter lockup?
Old Dec 17, 2005 | 04:43 PM
bigblu250's Avatar
bigblu250
Sorry, I should have been more specific. I meant the button at the end of the shift lever. It won't turn off overdrive while in Drive, if I shift to any gear other than Drive it works fine.
Old Dec 17, 2005 | 04:45 PM
ford390gashog's Avatar
ford390gashog
well in any other gear your will never enter into o/d anyway. also if you select 2nd you will always be in 2nd the tranny won't shift to second from first like in some gm trannies. t
Old Dec 18, 2005 | 09:05 AM
Casey's Avatar
Casey
The wire to the button is broken. Remove the plastic cover from the steering column and you should find a broken wire near where it enters the shifter. The insulation may be fine, but the wire inside is not.
Old Dec 18, 2005 | 09:20 AM
bigblu250's Avatar
bigblu250
Thanks Casey, that's the info I was looking for.
Old Jan 20, 2006 | 12:51 AM
rafman's Avatar
rafman
I've got the same problem and tried taking the plastic housing off. Got the 3 screws out but looks like igition switch is blocking. Is it just the 3 screws that need to be taken out? Thanks
Old Jan 21, 2006 | 01:28 AM
jake00's Avatar
jake00
can you put it in 2nd then take off od then switch to D?
Old Jan 21, 2006 | 02:20 PM
rafman's Avatar
rafman
Well, I tried that and a couple of other things and it looks like an intermittent in the wiring that's in the column housing. Since I wasn't able to get the upper housing off, I was able to use my finger to move the wires (they appear to have shrink tubing or something like that around them). So what I found is that if I push the wires towards the front of the truck, the OD lite works in P, R, N, D (only ignition on); I also found that it will work if I push the shift level towards the front of the truck.
So I'm back to trying to figure out how to get the upper column housing off. I took a couple of pics this morning and they are in my gallery.
Old Jan 21, 2006 | 05:21 PM
ajordan193's Avatar
ajordan193
didn't think anyone else would have this same problem. From the info you all posted i'm going to go have a look at mine and see if that same wire is busted. I will post later on my status. Thanks
-Andrew
campbell99
Oct 28, 2023 08:42 AM
NBT22555
Jun 25, 2014 01:32 PM
firstcerberrus
Aug 23, 2011 06:19 PM
MTGunner
15
Jun 11, 2010 06:08 PM
cacarroll
1983 - 2012 Ranger & B-Series
Aug 14, 2006 08:13 PM
