Offroad & 4x4
Steer Box Rebuild?
Old Dec 17, 2005 | 01:33 AM
74fordtruck's Avatar
74fordtruck
Steer Box Rebuild?
I just ordered a complete seal kit for my power steering box, in my 76 f100. Just wondered if anyone has rebuilt one of these, and if there are any particular tips I should be aware of. THANKS!
Old Dec 17, 2005 | 08:33 AM
fishmanndotcom's Avatar
fishmanndotcom
i've rebuilt a couple and one of them was my drilled and tapped boxes and it was really easy! just make sure to get some brake cleaner or gas and CLEAN everything. also before you button everything up, remember to pour just a little bit of fluid in so it helps lube everything up better
i had a really badazz article that i used but i can't find it. i'll see if i can dig it up. its not of your exact box but it should be very close to the same thing
EDIT... ok here it is i found it, https://www.ford-trucks.com/lc/lc.ph.../sbr/index.htm
have fun
-cutts-
Old Dec 17, 2005 | 12:29 PM
74fordtruck
Thanks for that article, that doesnt look as bad as other things i've done (d44 axle seals ) I'll hop right to it as soon as the delivery man brings me the goods
Old Dec 17, 2005 | 12:33 PM
shift1313's Avatar
shift1313
its not bad but like he said put a little fluid on everything, especially the seal when you are sliding the splined shaft back in. also i think you are supposed to loosen the backlash adjust up almost all the way? One thing is to make sure you have a seal driver or something the right size to get that new seal in. I think the hardest part was getting the pitman arm off to tell you the truth.
Old Dec 17, 2005 | 02:50 PM
ivanribic's Avatar
ivanribic
Are you doing a complete rebuild or just the basic seal kit? I did a complete rebuild when I tapped my box (steering box that is) for the hydro but really I think most people will only need the basic seals replaced, like the sector shaft seal and the steering shaft.
Old Dec 17, 2005 | 04:38 PM
RawPower's Avatar
RawPower
Mine always comes off pretty easy, but its not rusted at all... I just got a cheapo $10 pitman arm puller from AZ and it work very well when paired with an air socket wrench...then that broke wo I used a 1/2" socket wrench for it and that worked just as well, but longer...
Old Dec 17, 2005 | 04:59 PM
shift1313's Avatar
shift1313
mine wasnt rusted at all(due to the leaking fluid) but i had to use a heavy duty air impact to get it off using a puller.
Old Dec 17, 2005 | 06:00 PM
RawPower's Avatar
RawPower
guess yours was tourqued tighter. but now that I think about it, it was pretty hard using the socket wrench. I tend to have worse luck with pulling serp. belt pullies...
Old Dec 17, 2005 | 07:21 PM
74fordtruck
I ordered the complete seal kit, but it looks like i pretty much have to take the entire thing apart to do it anyways. that way I can clean everything up and all. The box doesnt have anyprobles, just leaks.
arkredneck
Nov 22, 2014 08:28 AM
7.3 forever
Aug 25, 2014 06:42 PM
Steve
Jul 7, 2014 08:27 AM
paker
1997 - 2003 F150
Oct 18, 2011 07:06 PM
M6EV139445
Oct 23, 2006 10:09 PM
