Offroad & 4x4
possibly a stupid question but...
Old Dec 16, 2005 | 05:11 PM
bsmotorsports's Avatar
bsmotorsports
I had a guy ask me a question today that kinda stumped me. I dont think it would be possible but...
A guys got a 2wd 90 f150. He asked me if a 1990-1996 4wd suspension lift would work on his 2wd....??
I told him most likely not, unless where his front suspension bolts up was exactly the same as the 4wd front suspension.
They should both use the same ttb front suspension arms correct??
And they both run off of the same radius arm setup right??
And the springs should fit his truck the same way as the 4wd.....
So would it be possible, or is it totally different???
Old Dec 16, 2005 | 06:57 PM
brokebronco's Avatar
brokebronco
As Ed McMahon yoused to say "You are right Sir!". The mounting points on the half tons are the same for 4x4 and 2 wheel drive. That makes it not too hard to convert to 4x4.
Chris
Old Dec 17, 2005 | 08:30 AM
fishmanndotcom's Avatar
fishmanndotcom
its a direct swap over, everything is the same
yes
yes
it'll work
-cutts-
Old Dec 17, 2005 | 11:45 AM
chrono4's Avatar
chrono4
all the same, itll work.
Old Dec 17, 2005 | 03:50 PM
bsmotorsports
Awesome, thanks guys. I love this forum.
Old Dec 18, 2005 | 08:59 AM
Tom92F150's Avatar
Tom92F150
I'll fourth that. It works. I converted my '92 F150 earlier this year. There are a few pictures in my gallery. If your buddy has any questions, I'd be glad to try to answer them.
Old Dec 18, 2005 | 09:31 AM
Mark Wenner's Avatar
Mark Wenner
Are you guys SURE about this? As I read the question he's not asking whether his friend can convert his 2wd truck to 4wd (which can certainly be done), he's asking whether a 4wd lift kit can be used on a 2wd truck. The mounting points may all be the same, but I don't know if all the brackets themselves are the same - I'm guessing it's not a direct fit.
Old Dec 18, 2005 | 10:05 AM
brokebronco
Still the same answer. If the mounts are the same between the 2 and 4 wheel drive, they are still the same when you lift it.
Chris
Old Dec 18, 2005 | 10:14 AM
Tom92F150's Avatar
Tom92F150
Yeah, I probably should've read the question more closely. 2wd rear leaves are 2.5" wide and the 4wd are 3" wide. The front bracketry is exactly the same. The TIB front is about 1.5-2" lower than the TTB, all else being the same, though.
