Windshield Squiters
Old Dec 17, 2005 | 12:08 AM
deisele75's Avatar
deisele75
Windshield Squiters
Has anybody put better windshield squiters on their truck. I have been spoild by the newer cars that get the whole windshield wet; whereas ours our a strait jet.
Old Dec 17, 2005 | 12:30 AM
derherr65's Avatar
derherr65
Not yet. I played with it on my mustang a little though. I'd hit the junkyard for the nozzles and pump off a car that has the pattern you like.
Old Dec 17, 2005 | 11:05 PM
Mil1ion's Avatar
Mil1ion
If you take your Straight style jets and blow them out with some air they will work better.
They corrode inside as well.
A Strait is a body of water running between two land masses.
ie: The Georgia Strait.
Old Dec 18, 2005 | 03:19 AM
deisele75's Avatar
deisele75
Good homonym, I'm really bad with those.
I did clean them good. I boiled them in water, and water flowes fine, I just wish they covered the windshield better.
Old Dec 18, 2005 | 03:27 AM
ford390gashog's Avatar
ford390gashog
my problem is the one on the drivers side sprays better. i am looking to use a high pressure unit from a newer ford truck or a late model saturn. those put out almost 7 psi compared to these which makes 1-2 at best. fairly simple just 2 wires 2 bolts and a hose. you can't use the sprayers that are hood mounted , because of the abrupt slant of the windshield.
Old Dec 18, 2005 | 02:01 PM
Mil1ion's Avatar
Mil1ion
I'm thinking of installing the one from the 88 Lincoln.
They have a great V pattern.
