dattime running lights
Old Dec 16, 2005 | 06:37 PM
adsacu's Avatar
adsacu
Just bought a 05 f-150 supercrew. When do the day time lights work? Mine never come on. Does anyone have wiring diagrams?
Old Dec 16, 2005 | 07:50 PM
Dunk's Avatar
Dunk
Isn't that a GM thing??
Old Dec 16, 2005 | 08:13 PM
Coupleofords's Avatar
Coupleofords
DTL not standard. Factory module + kit avaiable at Ford parts.
Old Dec 16, 2005 | 10:00 PM
EnergizerBunny69's Avatar
EnergizerBunny69
You do have auto headlights on your truck. (When the switch is turned all the way to the left, your headlights will come on about dusk or slightly there after, unless you have dark tinted windows, and then it is a little bit sonner.) But sorry, you do not have daytime running lights. You can get them if you want them. Install aftermarket switch and or relay system. There are kits available. Sorry that you bought the wrong vehicle, this is a FORD, not the competition.
Old Dec 17, 2005 | 12:22 PM
d0n_3d's Avatar
d0n_3d
actually I just bought a new 06' FX4 from my local dealer (had it optioned out the way I wanted it) and he asked me if I wanted daytime running lights...I said no...so??? maybe there really is an option?
Old Dec 17, 2005 | 01:17 PM
spiggy769's Avatar
spiggy769
One of these might help you out
Daytime Running Lights
Old Dec 17, 2005 | 01:33 PM
Dazz's Avatar
Dazz
On the '04 the "Autolamp - Automatic on/off headlamps" comes only on the XLT, FX4 and the Lariat as a Standard Option. Not available on the XL or STX.
I can imagaine if one pre-orders their F-150 they can leave off any standard option they wish, i.e. if you do not want it they will not install it.
With auto headlamps turn the light switch so the top of the switch is to the far left where it should be pointing to a symbol that appears like an asterisk (*) with a small "A" in the middle.
Old Dec 17, 2005 | 05:28 PM
adsacu's Avatar
adsacu
ok let me start over, I bought a 05 xlt with auto lights. there are lights in the bumper with bulbs, but they don't seem to work.
Old Dec 17, 2005 | 06:39 PM
Dazz's Avatar
Dazz
A ha! Those are the Fog Lights. Don't ask me why fog lights are white instead of yellow.
To turn on the Fogs turn your light switch to to any postion to the right, then pull the switch toward you.
Not to worry. I had the same problem.
Old Dec 17, 2005 | 07:08 PM
turkyhntr's Avatar
turkyhntr
When I purchased my 04 SCab, the lights were an after market option thru Ford, Coupleoford was right! Make sure you buy them thru Ford, they work perfect. They do not run on full brightness in the day time, and switch to nightime on there own, they install a light sensor, fits perfect on the left interior front post, no wires showing etc.
Old Dec 18, 2005 | 01:08 PM
adsacu's Avatar
adsacu
thank you Dazz that worked.
