Anyone ever make a brochure?
While you can use MS Publisher to produce a brochure for business use, it's not the best program, but, it is the most accessible.
I use a program called Quark XPress. This is one fine layout and design program. (Probably the 'Premier' program for layout/design.) A lot of magazines and newspapers use this program.
In setting up a brochure, you need to decide what format or size you will be ending up with. 8-1/2 x 11 trifold, 5-1/2 x 8-1/2, etc., etc., and go from there.
Keep in mind what you want to convey, and end up with sort of like a business card on steroids.
If you have MS Publisher, give it a try. This program is not that difficult, and has a so-called 'wizard' to help.
Believe it or not, most brochures are re-hashed information. Go pick up a brochure (or two) from other companies or businesses and see what theirs looks like, and while I don't advise 'copying' their design, it will give you ideas.
EDIT: Don't forget to add lots of photos. Visual aids are great at showing what you are trying to sell, trade, or produce in your business.
Example. . . don't just show a shock absorber - - - show the shock on the vehicle, from under the vehicle.
There are lots of 'public domain' pieces of artwork that you can use. Take advantage of it.
Keith
Having no idea what you're making a brochure of or for, I'd say make sure you show it to a number of different people, with different levels of knowledge about the subject. Sometimes, when you are writing about something you know a lot about, you omit information that the "average" person doesn't know. And, looking at lots of other brochures is a good tip, too. See what you like and don't like, and adapt it to your uses.
Granted, I had some typesetting skills from running a linotype machine years ago.
My supervisor brought in a box with the program in it, and said, "We are going to start using this program, tomorrow. Get acquainted with it."
I came home, called up PC Connection and $400 later, I had the program delivered to my door. (That was 10 years ago.)
Quark is all about layers and layering.
Not to use up bandwidth, but, start out with your paper size, say letter sized paper, landscape. (11" from left to right.)
Find the center. Work 'out' from there. You will need margins on each side, with a 'gutter' (inside margins) in the middle.
Proceed from there. It is truly an easy program to learn. 1/10th the time of other programs like Pagemaker or InDesign. (I've used them both.)
Popular Mechanics is just one mag that uses Quark. It is THAT good.
I wish that there was a way that I could send you a basic layout. I could do one for you in a matter of minutes.
Go to quark.com and see what the program is about. They did have a student 'discount' program. (As long as you have a "valid" student ID, there was a substantial discount on the program!!!) Welllllllllll worth the discount!!!
Hundreds off!
EDIT: If you are going to produce this at home, one really good paper is Hammermill 'Color Copy' paper. It is 28lb, matte finish. Photos look really good on this, and printed copy is fantastic. The last I purchased, letter sized stock was a little more than $8 per ream (500 shts.). (Cheaper if you buy it by the case.) I buy it 40,000+ sheets at a time. Also in 11 x 17" size.
After you 'create' your design, you could take a disc/CD to Kinko's or Staples, or some other place that does color copies. Call around and compare prices. This 'digital' printing is all the rage, in today's world.
Producing your brochure on a desktop printer could wind up being really expensive, considering the cost of ink cartridges and/or toner cartridges.
Keith
Brochures are easy, I was required to do one in 4th grade, (before i had a comp 1989) so anything since that hand written one has been cake
I do think that Quark has a demo version, but, anything that you print will have 'Demo' as a 'watermark' diagonally across the sheet.
As for taking something to Kinko's or Staples, (depending on the file size) either save to a Zip Disk or to CD. (Don't forget to 'Collect for Output' - which puts a copy of the artwork and fonts and all specifics into a designated folder.)
OR, you could convert the Quark file to Adobe (.pdf) and the file will be really small (in comparison) and then save to disk or CD. This would probably be the best bet. (Personally, I haven't used Kinko's or Staples, so, you might want to contact the one you will use, for their requirements.)
Quark XPress is really not that difficult to learn. I 'tutored' one of my daughter's roommates, and she was able to learn it, in an afternoon. This young lady went on to 'real' classes, and is now a graphics designer/layout specialist. It's a decent living.
I hope this helped.
Keith
Also when I import a group of pictures over a background picture and have it clip non white areas it does a good job but will leave some white around the new pictures, how do I touch up this white to match the master picture behind it?
If I had if able I could make it a picture and use mspaint but it must have a way. Also any place I can get samples of work to see how the boxes are laid out? THanks
(Look at the lower left corner of the screen. You can either click and drag through that percentage (100%) for example, and type in 500%. It will immediately show the image/project at 500%. Or, you can use the magnifying glass on the tools display and enlarge where you want, up to 800%.
First, de-select 'Automatic Text Box' when you start a new document or project.
Next, when you open Quark and create a new document or project, click 'View' - Show Tools.
Next, click 'View' - Show Measurements.
(I move the tools to the extreme right hand side of the screen, and put the measurements at the top of the screen. That's where I leave them.)
Don't clip 'non white' areas. When you insert a picture box, click 'Item' -'Modify' - 'Runaround' - Find 'Type', then select 'None' - 'OK'.
Doing this, you can put the photo wherever you want, and you don't have to worry about 'white areas' or text or photos 'knocking out' anything else. (Depending on your artwork/photos.)
I have only had to 'clip non-white area' about 5 times, total, in about 10+ years.
As for samples, peruse the internet for brochures, or go to local shops and pick up one of their brochures.
EDIT: Select 'No Runaround' for your Text Boxes, too. In this way, your type will 'float' over your background.
Instead of using up bandwidth, PM me if you have any other problems or questons.
I hope this helped.
Keith
