Name that rear...
Old Dec 16, 2005 | 03:49 PM
Sawbones25's Avatar
Sawbones25
Name that rear...
This the rear under my 1984 F-250. See Sig for more info.
I don't see any tags or anything stamped on the axle anywhere. It may be covered in rust or mud, but I can't find it...
Anyone know what this is?
Dana 60, Dana 70, etc...
Old Dec 16, 2005 | 04:18 PM
ivanribic's Avatar
ivanribic
Looks to be a D60. Take a wire brush and clean the webbing above the rear cover, I believe the right hand side but possibly the left. If it's a D60 it will have a "60" cast into the webbing.
Old Dec 16, 2005 | 04:26 PM
84-250's Avatar
84-250
the yellow circle should have the data tag between the two bolts, and the red circle has the "60" cast in it.
Old Dec 16, 2005 | 09:13 PM
fordraceboy's Avatar
fordraceboy
it's a 60... no doubt.
Old Dec 16, 2005 | 11:11 PM
Sawbones25's Avatar
Sawbones25
Thank you, thank you...
There is no tag on there and I can't see any numbers stamped into the housing anywhere. I must've gotten a freak axle where they forgot to stamp it or something...
Old Dec 17, 2005 | 06:34 PM
ivanribic's Avatar
ivanribic
The tags are sometimes missing since they're held on with the diff cover bolts. A lot of times people will pull the cover and forget to replace the tag when they reinstall it.
