I purchased a 2001 f350 that has been lowered. ( yes, I am an idiot) The lowering kit was a DJM beam.
I am going to replace the front coil springs, (which I suspect had been heated
in the lowering process), and the sway arm link bushings, ( to cure the clunking noise that I learned of on this site).
I already replaced the ball joints and shocks.
Any opinions on springs or other things I should look for in the front end?
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
