HEED HELP...I HAVE A 2000 150 W/ 5.4, IT WILL RUN FOR AROUND 10 MIN THEN DIE WHEN IT DIES THE ODOMETER GOES TO STRAIGHT LINES INSTED OF MILEAGE, i DONT KNOW IF THIS HAS ANYTHING TO DO WITH IT. AFTER 10 MIN OR SO IT WILL START UP AGAIN. I TOOK IT TO A LOCAL MECH. SHOP THIS IS GOOD AND THE TOLD ME HE DOSE NOT KNOW WHAT IS WRONG, HE DID SAY THAT THE FUEL PUMP SHUTS OFF, HE TRIED TO CHANGE THE FUEL PUMP RELAY AND NOTHING CHANGED HE SAID TAKE IT TO THE DEALER.
I TOOK IT TO THE DEALER AND THEY SAID IT NEED A FUEL PUMP AND A MAF
AND IT WOULD COST ME AROUND $900. I TOOK IT HOME AND FIXED THOSE PROBLEMS WITH FORD PARTS AND SAME THING. i TOLD FORD AND THEY SAID THAT I SHOULD HAVE HAD THEM DO IT.
SOMETIMES U CAN BE GOING DOWN THE HWY AND THE GAGE POD WILL FLASH AND IT WILL GO OUT OF GEAR. THEN IT WILL BE OK AFTER A FEW SEC
ANY HELP WILL BE APPRICATED
