Some maintenance questions
Old Dec 15, 2005 | 12:37 PM
35w's Avatar
35w
First let me say thanks for info from my first post. I have a couple questions about my truck which will be my first 4x4.
1 The fluid in the transfer case the same as the trans. Do each have their own
reservoir or they connected. How often to drain.
2 What type of maintenance is required for the front hubs. I went with ESOF
anything I should be aware with this feature.
3 When should you drain the diffs the first time.
4 Is it necessary to use a coolant filter? If so what level of difficulty to install.
Thanks 35w
Old Dec 15, 2005 | 01:40 PM
StrokerAce's Avatar
StrokerAce
1) not connected. Check owners manual for drain interval.
2) None, unless you're picky or are having problems. If the hubs aren't used often they can become tough to turn manually. Pop the cover & lube.
3) Check owner's manual for service interval.
4) not necessary but it's good for the water pump, radiator, etc. Here are some pics from a coolant filter I cut in half a few weeks ago. Also, note that if you are running the factory GOLD coolant fill you are good for 100k miles as long as you top off with 50/50 DISTILLED water and coolant. If you let the dealer flush it (he will replace with tap water) then you're only good for 50k and might need to test and add SCA depending on test results. Bypass coolant filters come in 2 ways: 1-regular filter with no SCA additive. 2- filter with SCA. Once you add SCA to the Gold coolant it's no longer good for 100k either.
http://i4.photobucket.com/albums/y113/Ares45/coolantfilter1.jpg
http://i4.photobucket.com/albums/y113/Ares45/coolantfilter5.jpg
http://i4.photobucket.com/albums/y113/Ares45/coolantfilter2.jpg
http://i4.photobucket.com/albums/y113/Ares45/coolantfilter4.jpg
http://i4.photobucket.com/albums/y113/Ares45/coolantfilter3.jpg
Old Dec 15, 2005 | 05:40 PM
wylecoyote's Avatar
wylecoyote
You can get sca additive for gold coolant ( extended life ) They sell 2 versions of the sca additive.
henduford
2004 - 2008 F150
Jul 21, 2013 12:57 AM
blue_dreams
Oct 27, 2012 03:23 PM
cruisetopdown
Apr 29, 2011 07:45 PM
ale & wenches
Jan 3, 2011 04:17 PM
89broncoidlehigh
Mar 9, 2004 09:08 AM
