Smell gas when starting cold
Old Dec 15, 2005 | 09:50 AM
Don222's Avatar
Don222
I've had trouble for 2 winters with flooding. I've had the plugs and wires and 02 sensors changed (2 times for 02 sensor). It has just gotten cold here in the last couple of weeks and now smelling gas when starting. Doesn't seem to be as bad if the block heater is plugged in.
Please help
Old Dec 15, 2005 | 10:48 AM
andym's Avatar
andym
Welcome to FTE....
First thing we need to know is what year and model the truck is. What engine would also help. I'm assuming it's fuel injected. It sounds like you may have an injector sticking. If you have a fuel pressure gauge, you can test for that condition. I would also pull the codes in case you have a sensor out of line.
http://www.midimonkey.com/~frederic/f350/eec-codes.html
Old Dec 15, 2005 | 10:55 AM
Don222's Avatar
Don222
Thanks Andy,
1992 302 fuel pressure was checked last winter. was all ok. 02 sensor was only bad code then. changes for 2nd time. What about the fuel pressure regulator??
02xlt3.0
1983 - 2012 Ranger & B-Series
Aug 7, 2013 05:57 AM
BluegrassPicker
Jul 20, 2011 06:39 PM
highboy
Aug 5, 2007 07:30 PM
shanemorse
Apr 27, 2007 10:46 AM
coolcat3406
1978 - 1996 Big Bronco
Sep 29, 2004 11:22 AM
