351m valve covers
Old Dec 15, 2005 | 01:02 AM
j.bluhm's Avatar
j.bluhm
351m valve covers
Does anyone know how tight the valve covers are supposed to be on a 351m. I replaced the valve cover gaskets because they were leaking like crazy...The bolts were tight. I just dont want it to start leaking again....it smoked and smelled pretty bad with oil dripping on the exhaust. Thank you
Old Dec 15, 2005 | 07:53 AM
74 F100 351m's Avatar
74 F100 351m
10-25 lbs of trq. Did you use alittle gasket sealer?
Old Dec 15, 2005 | 05:09 PM
53fatfndr's Avatar
53fatfndr
Use Permatex super high tack and you will never have a leak. But, I guess you already replaced them. Anyway, I just snug them down, 25 ft*lbs seems a bit much.
Old Dec 15, 2005 | 06:22 PM
j.bluhm's Avatar
j.bluhm
thank you very much guys. They arent leaking anymore.
Old Dec 15, 2005 | 10:13 PM
74 F100 351m
I sorry, I use a 1/4 drive and snug mine really well.
Old Dec 15, 2005 | 10:56 PM
Bill_Beyer's Avatar
Bill_Beyer
Uh...10-25 lbs/ft on 1/4" bolts? I'm thinking not unless you like trying to get headless bolts out of the heads. Standard TQ limits for 1/4" bolts is 6-9 lbs./ft. Maybe 10-25 lbs/in.
Old Dec 16, 2005 | 12:05 AM
roushracing617's Avatar
roushracing617
This may sound a little stupid, but no matter what engine I've replaced valve cover gaskets on, I use the same method. I use a 1/4" drive ratchet with the shortest extension possible, if any, and tighten it with my little (pinky) finger. I don't know what that comes out to as far as ft-lbs, but they never leak when I'm done.
jetfiremuck
Aerostar
Apr 13, 2017 08:26 AM
Maravich12
May 22, 2016 09:12 PM
ladelld33
Oct 12, 2015 06:53 PM
BonesNis
Oct 12, 2015 11:23 AM
ericw352
3.8 & 4.2L V6
Aug 8, 2010 12:18 PM
