motorcraft vs. holley 2bbl??
Old Dec 14, 2005 | 11:32 PM
F-150Guy's Avatar
F-150Guy
ive got a 81 f-100..with a 302 3spd auto. I just rebuilt the motor, and it runs pretty good...but im sure i could be getting better performance from my stock motorcraft 2150 2bbl. I know it needs a rebuild, because of the hard starting...unsteady idle, etc. But i would prefer buying a new carb, and maybe rebuilding the one i have already for fun when i have time. If i do go for a new carb, it wouldnt be anything big...maybe even a new or professionally rebuilt motorcraft 2150. But i heard Holley made a carb as a replacement for the motorcraft. What would be the differences between the motorcraft and the holley? difference in power? Mpg? reliability? price?
Any suggestions would be great..thanks
p.s the 302 is mostly stock besides an Rv cam, headers and 3'' exhaust.
Old Dec 15, 2005 | 09:23 PM
bob arrington's Avatar
bob arrington
use the holly ,bob
Old Dec 15, 2005 | 11:07 PM
F-150Guy's Avatar
F-150Guy
whats the difference between the two?
Old Dec 15, 2005 | 11:10 PM
ford390gashog's Avatar
ford390gashog
use the motorcraft. very simple,reliable and lasts a long time. the 2100 is a well designed carb, the off road guys use it and like it better than most 4bbl truck carbs. the kit is cheap only 12.00 to rebuild them and they have no gaskets to leak below the air horn like on a holley.
Old Dec 15, 2005 | 11:26 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
look on the drivers side of the carb and look for a number like 1.08, or 1.21 etc...that will tell us the size of the venturi's and the cfm...that would affect my descision if it was mine
if it turns out to have enough cfm, i would use it over the holley
Old Dec 15, 2005 | 11:49 PM
F-150Guy's Avatar
F-150Guy
how many cfms would be enough for an application like mine? (rebuilt 302 with an Rv cam, headers, exhaust)
Old Dec 16, 2005 | 12:02 AM
F-150Guy's Avatar
F-150Guy
i just went out and checked my carb...its a 1.08- 287cfm. Ive decided to go with the motorcraft, but cant decide between the 287 or the 350 cfm. How much of a difference would these two carbs make for power and gas mileage? any thoughts appreciated.
Old Dec 16, 2005 | 01:23 AM
ford390gashog
your 302 is pretty stock. 350 cfm is more than enough. too big you will loose low end torque. finding a 350 cfm 2100 carb is hard few were made. i found one on a 400 in a 72 station wagon.
Old Dec 16, 2005 | 09:35 AM
fmc400's Avatar
fmc400
MSEE
I've got a 350 cfm on a 400 in a Galaxie.
Old Dec 16, 2005 | 05:38 PM
F-150Guy's Avatar
F-150Guy
would you recommend the 350 over the 287?
Old Dec 17, 2005 | 01:39 AM
Ford_Six's Avatar
Ford_Six
A 350cfm would be much better than the 287. I ran a 350 on my 300-6 with an Offey intake, and it was fine clear up to 5500rpm. These carbs were usually on 360/390s and 351m/400 trucks, from 68-82. I have heard that the earlier ones had problems with casting porosity, but I haven't been able to confirm that.
Old Dec 19, 2005 | 12:39 PM
bob arrington
this forum is full of ' problems with rebuilt motorcraft carb', or'problems with rebuilding motorcraft carb' , if you have a choice between a new holly or a rebuilt motorcraft, especially if you are rebuilding it yourself and dont have a lot of experience , I would go with the Holly. you can get 'lucky' with your rebuild , if the motor craft has never been overheated , etc......... my 2c's,bob
Old Jul 20, 2021 | 01:37 PM
JWinter's Avatar
JWinter
Adapter plate
Hello, did you use an adapter plate on your 400 to install your holley 350?
Old Jul 21, 2021 | 06:44 PM
FuzzFace2's Avatar
FuzzFace2
If it had a Motorcraft v2 on the 400 then he would not need an adapter as it should be a bolt on.
Now what maybe an issue is any transmission linkage that hooks to the carb.
BTW you know this post was from 2005 right?
Dave ----
Old Jul 21, 2021 | 08:51 PM
JWinter's Avatar
JWinter
Dave ----
Yes I knew it was from 2005. It answered most of my questions so I thought I would leach on.
I see i do have a kick down so I may have to figure that linkage out.
Thank you for answering my question.
Chris Popanz
16
May 8, 2015 09:27 PM
jonny.redneck
Apr 23, 2014 04:43 PM
webster
Oct 30, 2012 02:28 PM
balingwire
Aug 31, 2009 03:22 PM
