Gearing Question?
Old Dec 14, 2005 | 10:31 PM
1980FordTruckMan's Avatar
1980FordTruckMan
Gearing Question?
hey yall,
just a quick gearing question. will 4.88 gears in a front axle with 4.85 gears in the rear axle work together without getting any torquebind?? i was taught that you could have a .03 difference. let me know what yall think. thanks.
Old Dec 15, 2005 | 08:33 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I would never run it on pavement...but I think it should be OK offroad.
Old Dec 15, 2005 | 10:51 AM
The SnoMan's Avatar
The SnoMan
It will work fine on and off the road. The difference is about .5% and of not real concern. Many years agon truck used to come with 4.09 in front and 4.10 in the rear. Ideally if you have to be off a littel, you want the slightly taller axle in the front, not rear if possible but again do not worry about it here.
Old Dec 15, 2005 | 07:47 PM
1980FordTruckMan
Thanks guys preciate the replys to my questions. i asked because i just recently put that set of 4.88 gears in the front axle...but i asked because when you have it in four wheel drive and the front hubs locked in and try to move the transfer case makes a loud banging noise and the rear axle will drag then roll a little bit then drag again and then roll again in sequence with the banging noise. if any one has any idea what might be causing this i would really like to know. thanks ya'll.
