I have a 1997 F350 Powerstroke and it has a Ford APCM in it and it reads 0 for the rpm display
the idle control works but it just does not read the rpm's
could it be just a disconnected wire or something minor
or do i need to get a new module
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
sounds like maybe a bad wire...
is yours the factory ford led unit?
but i think all our trucks come wired for them so i am not sure why it wouldnt be working. but as long as it adjusts the idle i guess all is ok i mean after all you can look at the tach.
btw a new one of those is like 600.00 from ford...i wanted 1 until i saw the price a few weeks back.
<META content=Diagnostics name=tps_proctitle><TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH vAlign=bottom align=middle>Problem</TH><TH vAlign=bottom align=middle>Action</TH></TR><TR><TD vAlign=top align=middle>APCM functions but control screen is blank
Reprogram the APCM with the latest level calibration
</TD><TD vAlign=top align=middle> </TD></TR><TR><TD vAlign=top align=middle>No backlight on ACTIVATE/DEACTIVATE (FORD/OVAL) key or POWER key
Check power and ground lines
</TD><TD vAlign=top align=middle> </TD></TR><TR><TD vAlign=top align=middle>When trying to enter a mode, light next to RPM CONTROL key or CHARGE PROTECT key blinks briefly but does not stay lit</TD><TD vAlign=top align=middle>
Ensure that enabling conditions are met
Parking brake engaged
Clutch engaged (foot off) or vehicle in PARK
Service brake off
Foot off accelerator
Brake lights connected and functional
With APC module turned off, use NGS Tester to determine if there are any brake or clutch pedal fault codes
For non-speed control vehicles (1995 MY only):
PCM may be incorrect. For manual vehicles, processor catch-word must be SOD4 or later.
For F250/F350/E350 automatic vehicles, processor catch-word must be TEE5 or later.
For Super Duty vehicles, processor catch-word must be PRY4 or later. The catch-word tag may be located on the vehicle "A" pillar or on the PCM itself.
</TD></TR><TR><TD vAlign=top align=middle>Display reads CErr for 5 seconds before normal display activation</TD><TD vAlign=top align=middle>
