Ford APCM Problems
Old Dec 14, 2005 | 09:15 PM
header's Avatar
header
Ford APCM Problems
I have a 1997 F350 Powerstroke and it has a Ford APCM in it and it reads 0 for the rpm display
the idle control works but it just does not read the rpm's
could it be just a disconnected wire or something minor
or do i need to get a new module
Old Dec 15, 2005 | 05:53 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 15, 2005 | 09:08 PM
header's Avatar
header
Thanks I'd appreciate that
Old Dec 16, 2005 | 07:52 AM
1997F-350's Avatar
1997F-350
sounds like maybe a bad wire...
is yours the factory ford led unit?
but i think all our trucks come wired for them so i am not sure why it wouldnt be working. but as long as it adjusts the idle i guess all is ok i mean after all you can look at the tach.
btw a new one of those is like 600.00 from ford...i wanted 1 until i saw the price a few weeks back.
Old Dec 16, 2005 | 07:16 PM
stroker2's Avatar
stroker2
Found this info on APCM diagnostics:
Diagnostics
<META content=Diagnostics name=tps_proctitle><TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH vAlign=bottom align=middle>Problem</TH><TH vAlign=bottom align=middle>Action</TH></TR><TR><TD vAlign=top align=middle>APCM functions but control screen is blank
  • Reprogram the APCM with the latest level calibration
</TD><TD vAlign=top align=middle> </TD></TR><TR><TD vAlign=top align=middle>No backlight on ACTIVATE/DEACTIVATE (FORD/OVAL) key or POWER key
  • Check power and ground lines
</TD><TD vAlign=top align=middle> </TD></TR><TR><TD vAlign=top align=middle>When trying to enter a mode, light next to RPM CONTROL key or CHARGE PROTECT key blinks briefly but does not stay lit</TD><TD vAlign=top align=middle>
  • Ensure that enabling conditions are met
    • Parking brake engaged
    • Clutch engaged (foot off) or vehicle in PARK
    • Service brake off
    • Foot off accelerator
    • Brake lights connected and functional
  • With APC module turned off, use NGS Tester to determine if there are any brake or clutch pedal fault codes
  • For non-speed control vehicles (1995 MY only):
    • PCM may be incorrect. For manual vehicles, processor catch-word must be SOD4 or later.
    • For F250/F350/E350 automatic vehicles, processor catch-word must be TEE5 or later.
    • For Super Duty vehicles, processor catch-word must be PRY4 or later. The catch-word tag may be located on the vehicle "A" pillar or on the PCM itself.
</TD></TR><TR><TD vAlign=top align=middle>Display reads CErr for 5 seconds before normal display activation</TD><TD vAlign=top align=middle>
  • Check communication lines
    • One may be open or shorted
</TD></TR><TR><TD vAlign=top align=middle>Display reads CErr</TD><TD vAlign=top align=middle>
    • Both may be open
  • Check vehicle model year
    • May be pre-1995 (module will not function in earlier modelvehicles)
</TD></TR><TR><TD vAlign=top align=middle>Display reads CrSd</TD><TD vAlign=top align=middle>
  • If communication lines are OK, replace APC module
</TD></TR><TR><TD vAlign=top align=middle>Display reads EErr</TD><TD vAlign=top align=middle>
  • APC component defective - Replace APC module
</TD></TR><TR><TD vAlign=top align=middle>Display reads AErr</TD><TD vAlign=top align=middle>
</TD></TR></TBODY></TABLE>
First item says if screen is blank, reprogram with latest calibration. I'm assuming that's something a dealership should be able to do for you.
Old Dec 20, 2005 | 11:46 AM
header's Avatar
header
Thanks Alot you guys
i will check into the calibration thing and see if that will help
thanks for the help
later
1972-34ton
Electrical Systems/Wiring
15
Dec 29, 2018 09:30 AM
bismic
Aug 10, 2015 10:35 AM
rmosso1
Jan 19, 2009 11:39 AM
TN-W124 Diesel
General Automotive Discussion
17
May 9, 2006 08:30 AM
Robbgt
17
Jan 5, 2005 08:47 PM
