6.0 questions
Old Dec 14, 2005 | 04:59 PM
jimbos250's Avatar
jimbos250
Red face 6.0 questions
i just resently got an 03 f-250 with a 6.0 and i heard about all the problems that they are having . whats the deal with the head gaskets and if the dealer replaces them will you still need to worry about them .also what would be the best chip to put on the 6.0 and why .what can or cant i do to the 6.0.
Old Dec 14, 2005 | 05:27 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Must read if you own a 6.0
https://www.ford-trucks.com/forums/s...d.php?t=325000
See you on the boards.
Enjoy FTE …..
Old Dec 14, 2005 | 05:35 PM
new2diesel2's Avatar
new2diesel2
Yes there are headgasket problems, but it seems it's more often w/ programmers be it the Predator, Superchips, Banks, whatever. Document all problems and take it to the dealer each time. If you get fluid spewing out of your tank, they'll replace the cap. That's where I'm at w/ mine. Don't worry about it till it happens. For now, use Diesel Kleen White bottle from Wal mart each fill up, and the gray in the summer, it helps keep the motor lubed and is better for cold starts, helps mpgs too. There's also a filter that you can get to put in the oil line I think, it helps keep the radiator clean. Sometimes they get clogged and this starts the gasket problems. There's a thread on here somewhere about it. Change your oil every 5k, your fuel filters every 15k, and your tranny fluid and filter every 30k. That should be enough to open the floodgates for everyone else w/ real knowledge. BTW, we all love our trucks and wouldn't have anything else!!
Old Dec 14, 2005 | 05:38 PM
clouden's Avatar
clouden
I am Opening myself up here but oh well.............the deal with head gaskets is that the chips produce too much boost/power, and head bolts stretch under load. (please no hate mail!!, just stating the expected)
The head gasket problem was explained to me like this...
first problem ford had was: rough cold start, runing rough at start-up etc. Solution was to design a program (i.e flash) to fix this. They developed one that raised rpm's at idle and fixed the problem. HOWEVER, this created a problem on the other end of the power range. Too much Rpm=too much boost or power under heavy loads, and BAM, stretched head bolts, blown gaskets, etc. I have since heard of a new flash they have come up to reverse this, but is not known if we will again have cold start issues.
I could be totally wrong, just a messenger from local Ford diesel tech, going through ford deisel certification now.
Old Dec 14, 2005 | 05:51 PM
jimbos250's Avatar
jimbos250
my truck now has 85k and i got it with 84k and im scared that when my warranty expires then ill start having problems. i read about people that had problems with the head gaskets and the dealer fixed it but after the dealer replaces the gaskets do you still have to worry about blowing the head gaskets again.
Old Dec 14, 2005 | 06:36 PM
Banshee Ben's Avatar
Banshee Ben
Usually if you make it to that many miles you will be fine. Most problems seem to be under 30k. If the gasket blew and is replaced? If they use a better gasket than I'd think good to go, if not then... I think once a bolt streches it looses it's strength so I don't know if it's manditory to replace them when a gasket blows. Overall I'd be fine with what you have but I don't know if i'd chip it. The 03 made the most power yet of the 6.0.
Old Dec 14, 2005 | 07:56 PM
jimbos250's Avatar
jimbos250
thanks for all your knoledge ben . i want to chip it i already have the intake im looking for a good exhaust and what would you recomend me for a chip and how far do you think i can take it in horse power. please guide me the right direction with exhaust and chip
Old Dec 14, 2005 | 08:24 PM
WeWeld's Avatar
WeWeld
Get an SCT tune with the tranny upgrades or you will be getting trans work real soon. If you want some info on some one to get you the right setup send me a PM.
GENE
Old Dec 14, 2005 | 08:42 PM
jimbos250's Avatar
jimbos250
hey gene i was already looking into the sct tuner you said to get it with the tranny upgrade ???? im new to the forum whats a pm.
Old Dec 14, 2005 | 10:00 PM
Banshee Ben
I will get a super chip.
(Superchips Inc. is of a true plug and play design.
ThreeSettings
80 HP / 120 FT LBS (Towing)
120 HP / 180 FT LBS (Economy, light towing)
150 HP / 225 FT LBS (Performance, light towing)
What ever you get I like a tuner that adds transmission data too. (increased line pressure and such) otherwise IMO as stated transmission work will be soon to follow. There are also "fuel adder" chips that add fuel but leave the transmission alone such as edge I think. The nice thing about fuel adders is that you can change settings on the fly where as tuners you have to access the chip and select a program. But I'd only get a tuner. A PM is a personal message. Click on the users name and select send private message or pm.
