Has anybody out there bought one of them tire changers that Harbor Freight is offering for $39.95? They look like they are pretty well made and was considering getting one.
I have used it to change everything from a 8" yard trailer tire, up to a 35 x 12.5 mud tire. You absolutely need to mount it down. I had it mounted to a sheet of plywood so I could move it, But now it is just mounted to the concrete outside the garage door. Works so much better.
The attached bead breaker leaves something to be desired. I welded some cross braces into it, and it made a big difference. But I usually use a Snap-on bead breaker that I have.
I have been using one as well, and if nothing more, it is handy to have it up off the floor where you don't have to bend over. I had to reinforce the bead breaker on the one my dad has, and will likely have to do it sooner or later to mine. I just ran a piece of flat iron perpendicular to the flat iron it had, and stitch welded it on, no problems.
