Light Timer
Old Dec 14, 2005 | 01:00 PM
njf207's Avatar
njf207
Light Timer
98 Explorer My Light Mod Does Not Seem To Work Anymore. Can Anyone Help.
Old Dec 16, 2005 | 06:35 PM
dirtydog43's Avatar
dirtydog43
What is a light mod?
Old Dec 16, 2005 | 08:36 PM
JerrySimm's Avatar
JerrySimm
Sounds like the Lights Out Module. What do you mean by it doesn't seem to work? There have been a number of posts regarding the Lights Out Module in this forum, you may want to run a search on it.
Old Dec 19, 2005 | 08:26 AM
njf207's Avatar
njf207
The timer for the lights insted of staying on for so many seconds they shut off as soon as you shut the door. It kind of sucks because I use the puddle lamps to see around the car while I have my son in my hands.
Old Dec 19, 2005 | 08:05 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Lightbulb
NFJ, have you tried to adjust it? There's a slide switch for the timer located under the rear-view mirror.....
Old Dec 20, 2005 | 01:40 PM
njf207's Avatar
njf207
Not the headlamps but the interior lamps they don't work. Although my mirror doesnt work well it does it just takes its good old time on the dimming side.
Old Dec 20, 2005 | 08:47 PM
thelonerangerxlt
NJF, I'll bet the interior lights have been turned off. There's an adjustment wheel to the right of the headlight switch that dims the dash lights. Try turning the roll wheel upward and see if that turns them on.
Old Dec 21, 2005 | 11:53 AM
njf207's Avatar
njf207
The lights work the timer just doesnt work as soon as you close the door the lights go off. They should stay on for like 30 seconds and they don't
Old Dec 21, 2005 | 09:08 PM
JerrySimm's Avatar
JerrySimm
It's probably the module, unfortunately I don't know where it is, and the wiring diagram on Autozone's site for your model doesn't show it. You might check with a dealership parts department and get them to show you a break down of where it is, or maybe a junkyard.
