intake leaking oil
Old Dec 13, 2005 | 05:19 AM
dmacfordshot04's Avatar
dmacfordshot04
intake leaking oil
my 86 351w f150 has been leaking oil for some time now,and i just now have time to tear it apart &replace gaskets.I did this twice on a 302&351 car.should it be the same job&does the the dist. have to come out again.that seamed to be the biggest pain in @#$&,was getting the dist out&back in again!thanks.
Old Dec 13, 2005 | 06:52 AM
Icicle's Avatar
Icicle
You dont have to pull the dizzy on a windsor motor to get the intake off if thats what your asking.....
Old Dec 13, 2005 | 07:11 AM
dmacfordshot04
according to my hanes man.it says i do.that would great if your right,because i have aLWAYS pulled it as prevously stated.
Old Dec 13, 2005 | 09:15 AM
fordborn's Avatar
fordborn
Thread moved to "221, 260, 289, 5.0/302, 5.8/351W V8" tech forum. Should receive more responses to the questions here.
Old Dec 13, 2005 | 05:44 PM
Icicle's Avatar
Icicle
perhaps a 351 is different, but you definitely do not on a 302
Old Dec 13, 2005 | 06:12 PM
imlikeojnow's Avatar
imlikeojnow
i dont see what you would have to pull the dizzy to change the gaskets, that doesnt make any sense at all.
Old Dec 13, 2005 | 06:13 PM
imlikeojnow
and by the way the reliabilty of the haynes manual leaves some room for improvement. i look in mine and it does say anything about the distributor rod for the oil pump at all. makes you wonder how many people have fried there engines using that manual
Old Dec 13, 2005 | 06:39 PM
ken75ranger's Avatar
ken75ranger
You don't always have to remove the distributor. If you don't pull it you need enough room to bring the intake in from the back at an angle. I find it easier to just pull it out.
Old Dec 14, 2005 | 06:22 AM
dmacfordshot04
i ll have to play it by ear &see if i have enough room.thanks.
