Question?
Old Dec 12, 2005 | 11:38 PM
reserve27D27's Avatar
reserve27D27
Question?
What will it take too convert my 1974 Ford F-250 360cid 4X4 auto from Mechanical fuel pump too Electric and if i miss a thread on this can somebody please direct me to it, I've spent alittle time here before i became a memeber looking information on this subject and may have missed something some where?
Old Dec 13, 2005 | 06:01 PM
bob arrington's Avatar
bob arrington
It can be simple or complex , being a simple person , I'll start with that . Buy an inline electric pump, disconnect your fuel lines from your mechanical pump, paying attention to the flow , install the electric pump in those hoses and tighten the clamps . Run the ground to a good ground and the hot either to ignition switched hot or to a manual switch that you can control fromn the cab. Install a fuse in the circut for safety. To mount the pump you may have to get longer fuel hoses to reach it to the frame . my 2c's, bob
Old Dec 13, 2005 | 06:07 PM
reserve27D27
awesome but do i need to place acover where the old pump sat to protect anything from where the old pump is or do i have to remove the old pump
Old Dec 13, 2005 | 08:56 PM
Ford_Six's Avatar
Ford_Six
The best thing is to remove the mechanical pump and put a block off plate on there. IIRC, the plate for big block chevies is the correct size and shape for most Ford pumps.
Old Dec 13, 2005 | 09:38 PM
reserve27D27
outstanding thank you all for the help
