Hi there,
I just signed in to this cool place.
my exp 98 is showing a 171 -174 codes. the MAF sensor is cleaned and good. Iddle is really bad when cold and runs ok when opp temp is reached.
could the EGR be bad? already checked ECT, leaks on manufold.
any ideas?
thanks
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page. JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
I played this very game with my 01 expy this weekend. I replaced MAF, checked all vac lines, intake leaks etc, then got hit with the stupid stick. 2 weeks ago when I replaced the plugs, I had inadvertantly knocked the PCV valve loose, and did not see it. Plugged it back in and its good to go. Check and make sure it aint loose, also check it where it hooks to intake, just feeling of it yesterday, it seems it would be hard to detect a leak.
