need under hood engine pic
Old Dec 15, 2005 | 07:42 PM
mike_94f250's Avatar
mike_94f250
Can someone send me an under the hood pic of a 351 engine (1993 - 1996)?
I've got a hose thats missing, I dont know how to begin to describe where its missing from or what all is missing. Truck is running rough. Thanks
mikeeaglin@yahoo.com
Old Dec 15, 2005 | 09:26 PM
donnor's Avatar
donnor
pics vs. diagrams
You may be better served with a copy of the diagram for you particular model. There are several variables in the range you cited. Prior to the 94 models all units under 8500 GVW would have been the same; and all those with a GVW of 8500 or greater would be alike. From 1994 on many units under 8500 had MAF air management, with phase-in to more each year. Your F250 (I just looked at your name/handle) should have speed density air management - unless it has been modified.
Check the underside of the hood - it should have a vacuum diagram decal unless the hood has been replaced or the decal has been removed.
dn.
Old Dec 15, 2005 | 11:17 PM
harjp1959's Avatar
harjp1959
Reading the above post, I don't know if these will help, but they are of my '95 250 5.8L:
