Bronco II Ford Bronco II
noisy lifters, fix
Old Dec 12, 2005 | 12:26 AM
ExMan01's Avatar
ExMan01
noisy lifters, fix
The lifters on my 2.8 are annoying. The truck runs great and I've heard this is a common problem, but what can I do to get rid of this. Can I buy new aftermarket lifters or replace the heads completely? School me
Ex
Will Mystery Oil "fix" this?
Old Dec 12, 2005 | 12:27 AM
ford390gashog's Avatar
ford390gashog
no mystery oil won't fix it. but a 15w40 diesel oil will lessen it. rusty in the fe forum used it in his.
Old Dec 12, 2005 | 12:29 AM
ExMan01's Avatar
ExMan01
diesel oil won't hurt the engine will it? Will it still pump it good enough?
Old Dec 12, 2005 | 12:31 AM
ford390gashog
diesel oil will be fine if not better than your current oil. diesel oil carries ratings for use in gas engines. they are labled SL/CI-4+
Old Dec 12, 2005 | 01:14 PM
broncobillyII86's Avatar
broncobillyII86
Kleen flo
705 Kleen Flo will lesson it alot too ...It's what I use works nice. TR
Old Dec 12, 2005 | 02:25 PM
mike93082's Avatar
mike93082
Adjust your valves. You will reduce the noise and also you will be able to replace the valve cover gaskets that are so famous for leaking on the 2.8 engines. The 2.8 has solid lifters so it sounds like your valves are out of adjustment.
Old Dec 14, 2005 | 10:52 AM
kernel-panic's Avatar
kernel-panic
I have a similar problem on my '87 2.9, and it's really noisy on first start-up, ESPECIALLY on colder mornings. I believe the 2.9 has hydraulic lifters though? Any advice for me, other than the oil? I need to replace the valve cover and oil pan gaskets anyhow... so I may have a look-see and check my specs chart(s) and see if anything is out-of-place/adjustment.
Old Dec 14, 2005 | 07:41 PM
Ken00's Avatar
Ken00
A common cause on the 2.9 is a clogged pump screen.
Old Dec 14, 2005 | 11:16 PM
fishindave11's Avatar
fishindave11
or install a dipstick oil heater. the warm oil will get up there faster!
Old Dec 15, 2005 | 01:10 PM
kernel-panic
So I've heard. I'll probably remove the oil pump pickup tube / screen and soak it in solvent and clean it up really good when I change out the oil pan gasket, as well as check out the valvetrain when I replace the valve cover gaskets.
Wouldn't surprise me much if the (my) 2.9 has the common Ford hydraulic lifter problem. I had an '86 Ranger 2.0L that had 5 of 8 lifters seized and 3 of the 5 were seized into the head and required a 10-lb slide hammer tool to effect removal. My other favorite valvetrain was a 351C-2V that had been rebuilt and put in a '67 F-100 I had bought when I was 18. Thanks for the tip(s).
Old Jan 2, 2006 | 06:31 PM
falcon5speed's Avatar
falcon5speed
try 1/2-3/4 liter of tranny fluid in the engine a week before you change your oil. It have worked on several engines for me like a miracle
Old Jan 2, 2006 | 09:16 PM
97Centurion's Avatar
97Centurion
Rub my Belly
Try adjusting them first but I ended up putting new lifters and an oil pump in my 2.9. No more tick!
Old Jan 2, 2006 | 09:51 PM
OSin86's Avatar
OSin86
Did you adjust them yet, that's all you should have to do.
Old Jan 4, 2006 | 10:27 PM
ExMan01's Avatar
ExMan01
Not yet, I'm gonna save up and convert to hydraulic lifters. Whaddya think?
Old Jan 5, 2006 | 07:56 AM
OSin86's Avatar
OSin86
Can you convert a 2.8 to hydraulic? If you can it seems like a lot of money and work compaired to just adjusting them.
428stang
2004 - 2008 F150
17
Apr 24, 2021 03:49 AM
428stang
Modular V8 (4.6L, 5.4L)
Apr 24, 2021 12:48 AM
Cman8469
May 18, 2020 12:57 AM
twister2gt
13
Nov 17, 2009 01:49 PM
ErnieX
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 2, 2007 01:08 PM
