how to wire in led to tc lock over ride?
Originally Posted by day jefro
how do you wire in led to tc lock over ride? if you are just grounding yhe wire out what makes it light up?
When going down hill with a trailer, it keeps the transmission locked up to slow you down (the engine helps with the braking). My favorite is going up hill pulling my camper. Keeping the torque converter locked and the transmission in overdrive, if you go up a small hill when the transmission would normally downshift to third (when it shifts from overdrive to third the torque converter unlocks for a second or two and really revs the engine) you can shift to third without the unlocking and high RPMs. This helps with drivablity and transmission temps.
Joe
Joe
Originally Posted by edub32
Ok thanks Joe. Are there any times where I shouldn't use the TC Lockup or where it could hurt my tranny?
Joe
T/C lock
Hey Joe, If you think the presure is to low to use the lock you should engauge yours off idle and see how fast the engine dies. Using this at low speeds is the whole ides behind this mod. I gained 1 1/2 mpg in town by lowering the rpms and slippage from the converter. You will generate way more heat in the trans by slipping around town. The stock line pressure is strong enough to lock the converter of idle and if you have the Sonnex valve thats all the better. I take of unlocked and engauge the lock at 12mph with my foot off the throttle. You can hardly feel the engaugement. I would like to know where the thread is for the blinking O/D light. My X doesn't do it but the Superduty does.
Originally Posted by ramsmoker
....... I would like to know where the thread is for the blinking O/D light.....
Look for the replies that refer to using a diode.
