WW come stock ??
Old Dec 20, 2005 | 06:10 PM
maevans's Avatar
maevans
WW come stock ??
Called Black Cloud Diesel today to order my wicked wheel and a few other goodies, told them i had a 99 psd with a manufacture date of 7/ 98.
After they double check they told me that my truck already came with the WW
They told me that a 4" exhaust would fix the surge/stall that i was trying to fix
with the WW. they also asked how much boost i was making, I told them when pulling my 11,000lbs Toy box , I can make 20lbs without any problem, so he also told me about the duel relief value.
Im looking for any advice of what i may need to fix the surge /stall i get when the automatic trany shifts from 2-3, 3-4, and as any one heard of a psd having a stock WW.
Old Dec 20, 2005 | 06:16 PM
hucka1a's Avatar
hucka1a
The obs trucks had ww's stock so did the early 99's. I would get the exhaust for sure. Try the waste gate mod
Old Dec 20, 2005 | 07:23 PM
Kwikkordead's Avatar
Kwikkordead
I don't know if this link will work.
It's a picture from Johnny8's gallery that shows the difference between the two intake wheels. Remove your intake boot and look down the throat of your turbo and see which intake wheel you have. The WW is the one with offset turbo blades. The late style is the one where all the blade ends are level with each other.
https://www.ford-trucks.com/user_gal...=91833&width=2
Old Dec 20, 2005 | 08:42 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Does the SES light come on when the boost is high? If it doesn't you don't really need the relief valve. It's purpose is to prevent the truck from defueling when an overboost condition occurrs, which doesn't happen until you go above 24 psi.
You'll have to look at the wheel of course, but the fact that it's surging so easily suggests that it may have the new style wheel, and you may need the WW.
Old Dec 20, 2005 | 08:52 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
hmm, the fact that it is surging so easily makes me think that it is the stock 10-blade even height wheel. my logic tells me that the 4'' exhaust will not help the COMPRESSOR surge/stall. the stall is when the air pressure at the turbo compressor outlet is greater than the pressure that the turbo is making, so it will make a huffing "whatwhatwhatwhat" noise. this is the actual wheel (that is spinning upwards of 100,000rpm) stopping in an instant (or getting really close to stopping) and the air pressure going back through and out of the turbo and out through the filter.
i dont see how anything other than an aftermarket wheel or compressor housing (ATS) will help reduce/eliminate stall.
Old Dec 21, 2005 | 10:10 AM
Fat Diesel's Avatar
Fat Diesel
You have an early 99 and it has the w wheel as std equipment. You can't put an ATS housing on it, it won't fit. Do your intake and exhaust and go with it. My turbo makes two noises. It sings beautifully under power, and gives me a nice big whooosh when I shift the six speed. I like it.
Old Dec 21, 2005 | 04:50 PM
maevans's Avatar
maevans
Went in early to work today to check and see if i did have a WW, I do have a stock
WW -10 blades, 5 at one level, 5 at a lower level just like the pic Kwik sent, To answer
cookie88 question about SES light, that light as never come on, Could it be possible this surge/stall be from my trany ?? And how are you guys able to use the blue quote
box when you reply. Thank you guys for all of info and your time. Merry Christmas!
Old Dec 21, 2005 | 09:45 PM
1984_355w's Avatar
1984_355w
We also have an early '99 and i would say that it sounds like a tranny problem. We see boost pressures of +30 with the predator on the 85 horse mode.
Old Dec 21, 2005 | 09:51 PM
cookie88's Avatar
cookie88
FTE Emeritus
box when you reply.
Click the button at the lower right corner of the post you want to reply to, and it will open the reply screen with the text already wrapped. From there you can look at the code wrap to be able to quote any text.
Old Dec 22, 2005 | 05:48 AM
maevans's Avatar
maevans
Thank You cookie88 for my computer lesson.
