Hello All
Old Dec 11, 2005 | 06:25 AM
novicefordowner's Avatar
novicefordowner
Hello All
Hello All
I recently bought a 1992 F150 from the original owner, it is a good truck but I found out that he never took it in for Factory recall I called a couple of the ford dealerships and was told that it was too old. So I have to do them myself. Has anyone ever changed out the fuel switch for Duel tanks? Any help would be appreciated. Thanks in advance
Old Dec 11, 2005 | 06:56 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 11, 2005 | 08:35 AM
subford's Avatar
subford
Originally Posted by novicefordowner
Hello All
Why do you want to change out the switch? There is no recall on the switch for any year that I know of. It is a Double-throw, Double-Poll Switch, what problems are you having with it?
PS, A 1992 does not have the mechanical fuel switch that was used from 1986-1990.
If you have the fuel crossover problem then you need to install check valves in your fuel system.
Old Dec 11, 2005 | 08:48 AM
quicklook2's Avatar
quicklook2
subford already wrote with what you need to fix.
welcome to fte. you will find a wealth of info here.
tell us more about your truck, options, miles, etc.
Old Dec 11, 2005 | 06:03 PM
Popa Tim's Avatar
Popa Tim
I'm not sure if safety recalls expire, check another dealer and this time ask if they could see if its been done to your truck. Have the vin# ready.
Welcome to Ford-Trucks!
Tim
Old Dec 12, 2005 | 09:57 AM
novicefordowner
fuel problem
Thanks to all who replied.
I was told from a dealer here in Houston that it would cost 900.00 to the problem with the fuel tanks, So i told him thanks and hung up. I'm also having a problem with the parking brake. It will not engage.
The Truck is a 1992 F150 with a 105,000 miles
has been retrofitted to except R134
power windows with aod transmission that seems to shift hard(but I'm not familar with this trans)
Old Dec 12, 2005 | 10:35 AM
subford's Avatar
subford
Tell us what your problem is and we will try to help.
$900.00 for what???
Old Dec 12, 2005 | 06:21 PM
novicefordowner
The problem is that if both tanks are full,and I'm using the rear tank the front tank overflows and spills out on the ground. I asked if it was a recall item and was told no and it would cost about 900.00 to fix.
Old Dec 12, 2005 | 07:23 PM
subford's Avatar
subford
Yes the recall you are talking about expired in 2004, I think it just consist of two check valves in the fuel lines. I think you can get the parts and fix it a lot cheaper than that.
Here is the recall you were talking about.
https://www.ford-trucks.com/recalls/.../y-1992/t-1632
